IVR Test Automation - Communicate Two IVR Apps - How To Send DTMF Prompt one to other.
Dehaaa
I'm trying to communicate two IVR application with each other . One of them is caller , the other is called. This idea for the test autimation on ivr flows . But there is an issue on when receiver IVR asks for an input which has only DTMF options , i need to send DTMF caller to called .
Is there any way to make custom vxml element on cisco to send dtmf value or signal to the receiver.
Or any idea to do this job using tcl or something like.
All things will be helpfull , thanks a lot.
0 Replies 0
