NCS1002 slice configuration with OpenConfig
Have you ever thought about automation of slice configuration on NCS1002 using open models?
YDK can help you with that! And to make your life even more easier, here are basic examples that show you all the logic behind models.
Use them, adopt them, improve them!
nc-edit-config-oc-terminal-device-20-ydk.py  Explains how to configure 2x100GE --> 2x100G mode
nc-edit-config-oc-terminal-device-22-ydk.py Explains how to configure 4x100GE --> 2x200G mode
nc-edit-config-oc-terminal-device-24-ydk.py  Explains how to configure 5x100GE --> 2x250G mode
nc-edit-config-oc-terminal-device-30-ydk.py  Explains how to configure 20x10GE --> 1x200G mode
nc-edit-config-oc-terminal-device-32-ydk.py  Explains how to configure 20x10GE --> 2x100G mode
More to come soon!
0 Replies 0
