Need to customize default link tooltip
aaikepae
I want to display customize tooltip on link.
I followed the same code as posted on http://xq.cisco.com/next/NeXtSite/demos.html#Tooltip/link
However, it is not working in my case.
Below is code snipped:
nx.define('MyLinkTooltip', nx.ui.Component, {
                properties: {
                                link: {},
                                topology: {}
                view: {
                                content: [{
                                                tag: 'p',
                                                content: [{
        tag: 'label',
        content: 'Source:'
        tag: 'span',
        content: '{#link.model.source}'
                                                tag: 'p',
                                                content: [{
        tag: 'label',
        content: 'Target:'
        tag: 'span',
        content: '{#link.model.target}'
                                                tag: 'p',
                                                content: [{
        tag: 'label',
        content: 'Status:'
        tag: 'span',
        content: '{#link.model.status}'
In porps parameter put the following code:
tooltipManagerConfig: {
                nodeTooltipContentClass: 'MyNodeTooltip',
                linkTooltipContentClass: 'MyLinkTooltip'
Please do let me know,where I want to do the changes to implement the link tooltip.
Sachin Samel
7 Replies 7
aaikepae
This two syntax cause error.
Change to :
content: '{#link.model.source.id}'
Same as target
chang to:
content: '{#link.model.target.id}'
ssamel
Community Member
Yes Abu. That solved my problem.
Another thing I noticed that, for boolean value false, it is not showing me any data. Can we handle it in a function which will return boolean values in string format?
e.g. content: function(){
                         //code to convert boolean to string format.
                         return str;
I tried like above code, but it was showing me the entire function definition in the popover.
Sachin
you can use converter to process data.
define a converter
var myConverter = {
          convert: function(value) {
               return value ? 'true' : 'false'
          convertBack: function(value) {
               return value == 'true';
and use it
content: '{#link.model.status,converter=myConverter}'
ssamel
Community Member
Thanks Abu.
Can you please explain what convertBack function does?
Sachin
ssamel
Community Member
Hi Abu,
I tried the converter function but it is not working.
It is not returning me any value if the value is false.
I tried to debug the converter function calling by putting console.log(value), but nothing is displayed in console.
Sachin
Hi Sachin,
this is  converter's syntax : 'key:{model,converter=converterName}'  , so if you can paste you code here, i can help on debug
Hi Sachin,
We use two-way binding for View and Model, so 'convert' mean from Model-> View and 'convertBack' means from View -> Model
