How do I display arrows
aaikepae
I am a new intern with Cisco so I am little unfamiliar with how things work. I have recently been trying out the Next API for my project where we need to display interactive graphs.  However, I had some problems and I am still new to Javascript so I haven’t yet figured out how to solve them. It would be great if you can guide me briefly.
[if !supportLists]1.       [endif]How do I display arrows, i.e to create a digraph?
[if !supportLists]2.       [endif]The labels for links appear to be overlapping. How do I fix this?
[if !supportLists]3.       [endif]Are there any more tutorials that go deeper into styling and handling of node events?
I have been studying the documentation extensively but am still a little confused.
Thank You.
Girish Kumar
aaikepae
you can reference this demo
Link Arrow - JSFiddle
aaikepae
For item 2:
Maybe you can change the behavior,  when mouse over a link then display it's label.
There is also a complex way to increase the distance between links. Extend nx.graphic.Topology.Link, set property 'offsetRadix' higher
aaikepae
For item 3:
You can reference this three demo
1. how to extend current node
http://xq.cisco.com/next/NeXtSite/demos.html#Extend/node
2. How to create you own node
http://xq.cisco.com/next/NeXtSite/demos.html#Extend/abstract
3. How to define scene
http://xq.cisco.com/next/NeXtSite/demos.html#Scene/extend
