netflow,cisco packet tracer
hi everybody,however I can use netflow command on router I couldn't use it on server on cisco packet tracer. So , is there any way to use netflow tab or any command that makes possible ? thanks for help...
omz
Are you trying to enable Netflow on server .. that is shows Netlfow collector?
If I remember correctly you only need to configure the router with flow commands and destination to send data to collector IP and config collector with IP.
This may help - https://www.packettracernetwork.com/tutorials/packet-tracer-netflow.html
