pyats command not found
SaffyT
Community Member
I followed - https://developer.cisco.com/docs/pyats-getting-started/
but when I ran command pyats it saying command not found
2 Accepted Solutions
omz
Are you using the virtual environment?
  1. Create a new directory:
    $ mkdir pyats
  2. Go to the new directory:
    $ cd pyats
  3. Initialize a virtual environment in this directory:
    $ python3 -m venv .
    Result: This creates a project “folder” (space) within the current directory. The folder keeps all dependencies, features, and components together in one place.
  4. Activate the virtual environment:
    $ source bin/activate .
Result: The system displays the directory in parentheses before the command prompt:
(pyats)$
Then install pip install pyats
If you are using a virtual environment .. don't forget to activate it .. source bin/activate
In the above example - pyats is the directory in which virtual environment is being created.
So you can do
cd pyats
source bin/activate
OR
source pyats/bin/activate
Claudia de Luna
Hi @SaffyT ,
@omz may have it and you just forgot to activate your virtual environment.
If you can send us the error you get including your prompt and CLI that would help as well.
I always recommend the full pyats installation.  See post below about half way down in the "Creating your Environment" Section.
https://gratuitous-arp.net/getting-started-with-pyats-and-genie/
Good luck and report back here if you are still running into issues.
omz
    $ mkdir pyats
    $ cd pyats
    $ python3 -m venv .
(pyats)$
So you can do
cd pyats
source bin/activate
OR
Claudia de Luna
Hi @SaffyT ,
