Open https for postman
ronsametcohen
Frequent Visitor
Frequent Visitor
Hello ,
How can I open https for connection and edit with postman ?
Thanks 🙂
@ronsametcohen Postman will automatically add http:// to the start of your URL if you do not specify a protocol, You can optionally type query parameters into the URL field, or can enter them in the Params tab. If your request uses path parameters, you can enter them directly into the URL field. For 'edit' this isn't supported on Postman as an HTTP method, you would need to use PUT or PATCH.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
balaji.bandi
check this below link to help you set up on the device and use postman to make your requirements to work.
https://www.postman.com/ciscodevnet
BB
