Operation not supported (FS MGR): InPlace Modify Error:
haoywang
Hi Experts
I'm trying to update the source match address in a class-map and YDK returned an error
YPYServiceProviderError: Server reported an error while committing change.
  error-type: application
  error-tag: operation-failed
  error-severity: error
  error-path: ns1:policy-manager/ns1:class-maps/ns1:class-map[type = 'traffic' and name = 'flow1_cm']/ns1:name
  error-message: Operation not supported (FS MGR): InPlace Modify Error:
  error-tag: backend-status-summary
  error-severity: warning
  error-message: QT/SysDB backend failed, non-QT backend passed [read rest of response for details]
The original XML config is:
<class-maps>
    <class-map>
      <type>traffic</type>
      <name>flow1_cm</name>
      <class-map-mode-match-all/>
      <match>
        <source-address-ipv4>
          <address>192.168.1.0</address>
          <netmask>255.255.255.0</netmask>
        </source-address-ipv4>
        <destination-address-ipv4>
          <address>192.168.100.0</address>
        </destination-address-ipv4>
      </match>
    </class-map>
I changed the 192.168.1.0 to 192.168.2.0 and the error occured. How can I achieve this goal?
8 Replies 8
saalvare
That error is not locally generated by YDK.  It comes from the router.  If you share your YDK code snippet, I can try reproduce and follow up on the what is causing the router to reject the config.
Hi, the code related is below:
def update_flow():
    policy_manager = PolicyManager()
    class_maps = policy_manager.class_maps
    cm = class_maps.ClassMap()
    cm.name = 'flow1_cm'
    cm.type = ClassMapTypeEnum.traffic
    cm.class_map_mode_match_all = Empty()
    source = cm.match.SourceAddressIpv4()
    source.address = '192.168.2.0'
    source.netmask = '255.255.255.0'
    cm.match.source_address_ipv4.append(source)
    dest = cm.match.DestinationAddressIpv4()
    dest.address = '192.168.100.0'
    dest.netmask = '255.255.255.0'
    cm.match.destination_address_ipv4.append(dest)
    class_maps.class_map.append(cm)
    provider = get_connection()
    update(provider, policy_manager)
    release_connection(provider)
I also tried to delete the PolicyManager.ClassMaps.ClassMap.Match.SourceAddressIpv4 object first and then add a new source address. The delete operation didn't raise an error but the source address is still in the config.
The code is:
def delete_test():
  p_object = PolicyManager()
  p_result = read(provider, p_object)
   for j in p_result.class_maps.class_map:
   for k in j.match.source_address_ipv4:
   print k.address
  delete(provider, k)
Can you try deleting the entire match and then adding the new match with the updated src-address?
I believe the problem you may be hitting is that the source address isn't independently updatable.
Cheers,
Einar
I've tried to delete the match object and a new error is raised.
  error-message: Policy manager does not support this feature: Classmap is empty,if class map no more required please delete class map 'flow1_cm'
Looks like I cannot delete the match object
Anton Abik
Level 4
Level 4
I tried to do same for my XR boxes and seems it works for me. Can you try to copy paste the code (in attachment) if it runs also for you?
  • The prints just iterate through the class map and print its name, type and source/dest ip addresses/masks
  • The edit_class_map function do the trick with addying IPs to class_map
EDIT: I am running YDK 0.5.3 and the version of my XR is 6.1.2
Thanks for your response.
I tried to run your script and there is no class-map named test_CM on my XR.
I guess your class-map is match-any and mine is match-all, so the result is different.
Can you show me the config on XR?
An error raised:
Traceback (most recent call last):
  File "/Users/Muyiwhy/Documents/workspace/ydk_bgp/module/ydk_class_maps-test.py", line 40, in <module>
    crud_update = crud.update (provider, policy_configuration)
  File "/Users/Muyiwhy/.virtualenvs/ydk-py/lib/python2.7/site-packages/ydk/services/crud_service.py", line 117, in update
    self._execute_crud_operation_on_provider(provider, entity, 'UPDATE', False)
  File "/Users/Muyiwhy/.virtualenvs/ydk-py/lib/python2.7/site-packages/ydk/services/crud_service.py", line 168, in _execute_crud_operation_on_provider
    operation
  File "/Users/Muyiwhy/.virtualenvs/ydk-py/lib/python2.7/site-packages/ydk/services/service.py", line 36, in execute_payload
    reply = provider.execute(payload, operation)
  File "/Users/Muyiwhy/.virtualenvs/ydk-py/lib/python2.7/site-packages/ydk/providers/netconf_provider.py", line 94, in execute
    return self.sp_instance.execute_operation(payload, operation)
  File "/Users/Muyiwhy/.virtualenvs/ydk-py/lib/python2.7/site-packages/ydk/providers/_provider_plugin.py", line 223, in execute_operation
    return self._handle_rpc_reply(operation, payload, reply.xml)
  File "/Users/Muyiwhy/.virtualenvs/ydk-py/lib/python2.7/site-packages/ydk/providers/_provider_plugin.py", line 242, in _handle_rpc_reply
    self._handle_rpc_ok(optype, payload, reply_str)
  File "/Users/Muyiwhy/.virtualenvs/ydk-py/lib/python2.7/site-packages/ydk/providers/_provider_plugin.py", line 255, in _handle_rpc_ok
    self._handle_commit(payload, reply_str)
  File "/Users/Muyiwhy/.virtualenvs/ydk-py/lib/python2.7/site-packages/ydk/providers/_provider_plugin.py", line 274, in _handle_commit
    raise YPYServiceProviderError(error_code=YPYErrorCode.SERVER_COMMIT_ERR, error_msg=rep)
ydk.errors.YPYServiceProviderError: Server reported an error while committing change.
  error-path: ns1:policy-manager/ns1:class-maps/ns1:class-map[type = 'traffic' and name = 'test_CM']/ns1:name
  error-message: Policy manager does not support this feature: Match all is the only mode supported for match type "destination-address-ipv4" in class-map type "traffic"
BTW: I'm using the same YDK and XR version as you.
Anton Abik
Level 4
Level 4
Nope mine is also match-all because you cannot specify match-any for match-source address or destination address. Error message from ASR if you want to configure it like that:
!!% Policy manager does not support this feature: Match all is the only mode supported for match type "source-address-ipv4" in class-map type "traffic"
end
Class map test_CM is my class map I am editing. So use your name in that code. Hopefully it will work. Here is mine config from XR:
RP/0/0/CPU0:TFI-LAB-XRv6.1.2-01#show run class-map
Tue Feb 28 14:18:42.900 UTC
class-map type traffic match-all test_CM
description This is my description
match source-address ipv4 10.0.0.0 255.255.255.0
match source-address ipv4 50.0.0.1 255.255.255.0
match destination-address ipv4 100.0.0.1 255.255.255.0
match destination-address ipv4 20.0.0.0 255.255.255.0
end-class-map
