PSIRT openvulnquery .csv output
William Giannattasio
Is there something to edit to be able to reorder the columns in the .csv file?
Thanks in advance!
Best,
Quite a specific question, as far as i recall the tool doesn't provide a direct option to reorder the columns in the CSV output. You can try and use the csvkit tool, which is a command-line utility for working with CSV files, specifically, you can use the csvcut command to reorder the columns or if you know some scripting the python pandas library might be an option.
If these do not work, i would suggest contacting the PSIRT/Talos team at Cisco.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
