pyats connection to n9k in aci mode
MykolasB74835
Hi, we think of monitoring state of ACI leaf interfaces, routes  during upgrade using pyats. Unfortunately I'm not able to connect to it using pyats.  When connecting pyats tries commands which are not supported by n9k aci mode. How do I specify os; type, series for n9k in aci mode?
my inventory looks like this:
devices:
  ACIxxxx:
    connections:
      cli:
        ip:  1.1.1.1.
        protocol: ssh
    credentials:
      default:
        password: xxx
        username: xxx
    os: 'nxos'
    series: 'aci'
    type: 'aci'
(venv) [username@dev-hostgenie-demo]$             cat interface_nxos_ACIXXXX_exception.txt
Issue while building the feature
Traceback (most recent call last):
  File "src/genie/cli/commands/learn.py", line 343, in genie.cli.commands.learn.LearnCommand._retrieve_ops
  File "/home/username/genie-demo/venv/lib64/python3.6/site-packages/genie/libs/ops/interface/nxos/interface.py", line 337, in learn
    self.make(final_call=True)
  File "/home/username/genie-demo/venv/lib64/python3.6/site-packages/genie/ops/base/base.py", line 101, in make
    self.maker.make(*args, **kwargs)
  File "src/genie/ops/base/maker.py", line 312, in genie.ops.base.maker.Maker.make
  File "src/genie/ops/base/maker.py", line 418, in genie.ops.base.maker.Maker._call_parser
  File "src/genie/metaparser/_metaparser.py", line 271, in genie.metaparser._metaparser.MetaParser.parse
  File "/home/username/genie-demo/venv/lib64/python3.6/site-packages/genie/libs/parser/nxos/show_interface.py", line 1283, in cli
    intf_lst = [interface]
UnboundLocalError: local variable 'interface' referenced before assignment
this is what happens when i try genie shell
venv) [username@dev-host genie-demo]$ genie shell --testbed-file demo-testbed.yml
Welcome to pyATS Interactive Shell
Python 3.6.8 (default, Jun 11 2019, 15:15:01)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-39)]
>>> from genie.testbed import load
>>> testbed = load('demo-testbed.yml')
>>> testbed.devices
TopologyDict({'ACIxxxx': <Device ACIxxxx at 0x7fa5de7c85f8>})
>>> testbed.devices['ACIxxxx'].connect()
[2020-05-25 17:25:50,090] +++ ACIXXXX logfile /tmp/ACIXXXX-cli-20200525T172550089.log +++
[2020-05-25 17:25:50,091] +++ Unicon plugin nxos +++
[2020-05-25 17:25:50,425] +++ connection to spawn: ssh 1.1.1.1., id: 140350372206968 +++
[2020-05-25 17:25:50,425] connection to ACIXXXX
Password:
Last login: Mon May 25 17:20:37 2020 from 2.2.2.2.
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2018, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
ACIXXXX#
[2020-05-25 17:25:53,678] +++ initializing handle +++
[2020-05-25 17:25:53,679] +++ ACIXXXX: executing command 'term length 0' +++
term length 0
bash: term: command not found
ACIXXXX#
[2020-05-25 17:25:53,757] +++ ACIXXXX: executing command 'term width 511' +++
term width 511
ACIXXXX#
[2020-05-25 17:25:53,833] +++ ACIXXXX: executing command 'terminal session-timeout 0' +++
bash: terminal: command not found
ACIXXXX#
[2020-05-25 17:25:53,908] +++ ACIXXXX: config +++
config term
bash: config: command not found
ACIXXXX#
  File "src/unicon/statemachine/statemachine.py", line 719, in unicon.statemachine.statemachine.StateMachine.go_to
  File "src/unicon/statemachine/statetransition.py", line 222, in unicon.statemachine.statetransition.StateTransition.do_transitions
  File "src/unicon/eal/dialogs.py", line 457, in unicon.eal.dialogs.Dialog.process
  File "src/unicon/eal/dialog_processor.py", line 306, in unicon.eal.dialog_processor.SimpleDialogProcessor.process
  File "src/unicon/eal/dialog_processor.py", line 265, in unicon.eal.dialog_processor.SimpleDialogProcessor.timeout_handler
unicon.core.errors.TimeoutError: timeout occurred:
              timeout value: 10
              last_command: 'config term\r'
             pattern: ['^(.*)(\\(maint-mode\\))?\\(.*(con|cfg|ipsec-profile)\\S*\\)#\\s?$', '^.*--\\s?[Mm]ore\\s?--.*$']
             buffer:'config term\r\nbash: config: command not found\r\nACIXXXX# '
The above exception was the direct cause of the following exception:
  File "/home/username/genie-demo/venv/lib64/python3.6/site-packages/unicon/plugins/generic/utils.py", line 60, in retry_state_machine_go_to
    prompt_recovery=prompt_recovery)
  File "src/unicon/statemachine/statemachine.py", line 722, in unicon.statemachine.statemachine.StateMachine.go_to
unicon.core.errors.StateMachineError: Failed while bringing device to "config" state
During handling of the above exception, another exception occurred:
  File "src/unicon/bases/connection.py", line 627, in unicon.bases.connection.Connection.connect
  File "src/unicon/bases/routers/connection_provider.py", line 149, in unicon.bases.routers.connection_provider.BaseSingleRpConnectionProvider.connect
  File "src/unicon/bases/routers/connection_provider.py", line 199, in unicon.bases.routers.connection_provider.BaseSingleRpConnectionProvider.init_handle
  File "src/unicon/bases/routers/connection_provider.py", line 121, in unicon.bases.routers.connection_provider.BaseCommonRpConnectionProvider.execute_init_commands
  File "src/unicon/bases/routers/services.py", line 192, in unicon.bases.routers.services.BaseService.__call__
  File "/home/username/genie-demo/venv/lib64/python3.6/site-packages/unicon/plugins/generic/service_implementation.py", line 868, in call_service
    prompt_recovery=self.prompt_recovery
  File "/home/username/genie-demo/venv/lib64/python3.6/site-packages/unicon/plugins/generic/utils.py", line 86, in retry_handle_state_machine_go_to
  File "/home/username/genie-demo/venv/lib64/python3.6/site-packages/unicon/plugins/generic/utils.py", line 64, in retry_state_machine_go_to
    raise SubCommandFailure(err, spawn.buffer)
unicon.core.errors.SubCommandFailure: (StateMachineError('Failed while bringing device to "config" state',), 'config term\r\nbash: config: command not found\r\nACIXXXX# ')
  File "<console>", line 1, in <module>
  File "src/genie/conf/base/device.py", line 636, in genie.conf.base.device.Device.connect
  File "src/pyats/connections/manager.py", line 334, in pyats.connections.manager.ConnectionManager.connect
  File "src/unicon/bases/connection.py", line 633, in unicon.bases.connection.Connection.connect
unicon.core.errors.ConnectionError: failed to connect to ACIXXXX
6 Replies 6
Claudia de Luna
Hi @MykolasB74835
ACI is supported to the extent NXOS is the same on ACI, if that makes sense.
Using the CLI you are correct in using OS as NXOS.   There is a customization you need to implement but first:
For ACI I always recommend using REST.    That's going right to the source and you get structured data back, rather than using the CLI which, lets face it, is a command overlay to make us CLI geeks more comfortable using ACI. :D which we then have to parse when we could have just gotten the data via REST already parsed.   Gets you away from parsing (data that was structured to begin with) and saves you a step.
https://pubhub.devnetcloud.com/media/rest-connector/docs/user_guide/services/apic.html#
But I digress..sorry about that.
Try this:
devices:
  nxos_aci_mode:
    os: nxos
    series: aci
    (snip)
    custom:
      abstraction:
        order:
          - os
          - series
The problem with this is that you will invariable run into issues when ACI "NX-OS" has slightly different output than NX-OS "Classic".
I agree, will ditch pyats for ACI and do through the REST
adding custom and abstraction didn't work until i added model, type. it still doesn't parse interfaces.
(venv) [username@dev-hostgenie-demo]$                                        vim demo-testbed.yml
devices:
  ACIxxxx:
    connections:
      cli:
        ip: 1.1.1.1
        protocol: ssh
    credentials:
      default:
        password: X7xxxxxxxx
        username: username
    os: nxos
    series: aci
    custom:
      abstraction:
        order:
         - os
         - series
"demo-testbed.yml" 17L, 295C written
(venv) [username@dev-hostgenie-demo]$ genie learn interface --testbed-file demo-testbed.yml
Argument should be a path to a pyATS testbed file, or a pyATS Testbed object not demo-testbed.yml
devices:
  ACIxxxx:
    connections:
      cli:
        ip: 1.1.1.1
        protocol: ssh
    credentials:
      default:
        password: xxxx
        username: username
    os: nxos
    series: aci
    model: aci
    type: aci
    custom:
      abstraction:
        order:
         - os
         - series
"demo-testbed.yml" 19L, 324C written
Learning '['interface']' on devices '['ACIxxxx']'
100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 1/1 [01:54<00:00, 114.21s/it]
| Genie Learn Summary for device ACIxxxx                                       |
|  Connected to ACIxxxx                                                        |
|  -   Log: ./connection_ACIxxxx.txt                                           |
|  Could not learn feature 'interface'                                         |
|  -  Exception:      ./interface_nxos_ACIxxxx_exception.txt                   |
|  -  Ops structure:  ./interface_nxos_ACIxxxx_ops.txt                         |
|  -  Device Console: ./interface_nxos_ACIxxxx_console.txt                     |
(venv) [username@dev-hostgenie-demo]$ cat interface_nxos_ACIxxxx_exception.txt
(venv) [username@dev-hostgenie-demo]$ cat interface_nxos_ACIxxxx_ops.txt
  "_exclude": [
    "in_discards",
    "in_octets",
    "in_pkts",
    "last_clear",
    "out_octets",
    "out_pkts",
    "in_rate",
    "out_rate",
    "in_errors",
    "in_crc_errors",
    "in_rate_pkts",
    "out_rate_pkts",
    "in_broadcast_pkts",
    "out_broadcast_pkts",
    "in_multicast_pkts",
    "out_multicast_pkts",
    "in_unicast_pkts",
    "out_unicast_pkts",
    "last_change",
    "mac_address",
    "phys_address",
    "((t|T)unnel.*)",
    "(Null.*)",
    "chars_out",
    "chars_in",
    "pkts_out",
    "pkts_in",
    "mgmt0"
  "attributes": null,
  "commands": null,
  "connections": null,
  "context_manager": {},
  "info": {
    "Mgmt0": {
      "vrf": "management"
}(venv) [username@dev-hostgenie-demo]$
You can still use pyats...just use the REST connector.   Particularly for testing, you may want all the testing extras you will get with pyATS.
Good luck!
Thanks, want to give a try. I'm so new pyats, struggling to get it structured understanding. I can do the basics with IOS and cli connectors by copy/paste from tutorials, but unable to understand documentation for more advanced things
- Does it work directly to NXOS in ACI mode?
- How would I specify rest.connector in testbed file?
- In general my use case is to take interface status and full routing table and monitor changes, is pyats the right tool for it? Or better I should just build my own rest query based script...
seems managed to get it working by looking at https://github.com/CiscoTestAutomation/rest/blob/master/connector/src/rest/connector/tests/testbed.yaml
(venv) [usernam@dev-hostname genie-demo]$ vim demo-testbed3.yml
devices:
  ACIxxxx:
    os: apic
    type: apic
    custom:
      abstraction:
        order: [os]
    connections:
      rest:
        class: rest.connector.Rest
        ip: 1.1.1.1
        username: xxx
        password: xxx
"demo-testbed3.yml" 13L, 249C written
(venv) [username@dev-hostname genie-demo]$ pyats shell --testbed-file demo-testbed3.yml
>>> testbed = load('demo-testbed3.yml')
>>> testbed.devices['ACIxxx'].connect(alias='rest', via='rest')
Connecting to 'ACIxxx' with alias 'rest'
<Response [200]>
Connected successfully to 'ACIxxx'
rdefreitas
Did you ever get your connection problem resolved? I am having a similar problem with pyats learning an ACI environment. It appears my rest connection is successful, but I ge the following error message below.
Learning '['interface']' on devices '['nexus-test-sw-01']'
Connecting to 'nexus-test-sw-01' with alias 'rest'
<Response [200]>
Connected successfully to 'nexus-test-sw-01'
0%| | 0/1 [00:00<?, ?it/s]Caught error while executing target in child process-0:
target = _retrieve_ops
args = (<Device nexus-test-sw-01 at 0x7f47a65a5fc0>, 'interface', '.')
kwargs = {}
File "src/pyats/async_/parallelcall.py", line 90, in pyats.async_.parallelcall.ChildLabor.run
File "src/genie/cli/commands/learn.py", line 338, in genie.cli.commands.learn.LearnCommand._retrieve_ops
File "src/pyats/topology/device.py", line 559, in pyats.topology.device.Device.__getattr__
AttributeError: 'Device' object has no attribute 'log'
My testbed yaml file
testbed:
credentials:
default:
username: admin
password: XXXXXXXXXX
devices:
nexus-test-sw-01:
os: nxos
platform: apic
custom:
abstraction:
order: [os]
connections:
rest:
ip: 10.XX.XX.XX
