pyATS: force output after login through terminalserver?
uheil
Hi!
I'm trying to login into a switch which is connected through a terminal server vis ssh.
When i login nothing happens and after a while i get
TypeError: device is not connected, output must be provided.
When i try with ssh "ssh -p 4002 username@10.10.10.2" login works but i need to press enter at least once before the switch prompt gets displayed.
My testbed file looks like:
testbed:
  credentials:
    default:
      username: '%ASK{}'
      password: '%ASK{}'
devices:
  SW1:
    connections:
      console:
        protocol: ssh
        ip: 10.10.10.2
        port: 4002
    os: 'ios'
    type: switch
    platform: '2960'
What can i do to trigger the switch so that it prints a login prompt after supplying the password?
I read about 'execute' and 'command' but i have no clue how to extend my testbed file.
uheil
Somehow i figured it out!
testbed:
  credentials:
    default:
      username: '%ASK{}'
      password: '%ASK{}'
devices:
  SW1:
    connections:
      console:
        protocol: ssh
        ip: 10.10.10.2
        port: 4002
        arguments:
          connection_timeout : 2
          prompt_recovery : true
    os: 'ios'
    type: switch
    platform: '2960'
Using arguments: and prompt_recovery.
With those settings in the testbed.yaml it tries to recover the prompt after 2 seconds (default is 60).
Would be nice if someone knows how to set the connection_timeout only for login and reset it afterwards.
uheil
testbed:
  credentials:
    default:
      username: '%ASK{}'
      password: '%ASK{}'
devices:
  SW1:
    connections:
      console:
        protocol: ssh
        ip: 10.10.10.2
        port: 4002
        arguments:
    os: 'ios'
    type: switch
    platform: '2960'
