How to assign BGP conf structure leafs
l00pback
Hello All,
Utilizing the Genie BGP conf library, one can populate necessary information inside the BGP conf tree
Bgp
  +­­DeviceAttributes
        +­­ PeerSessionAttributes
        +­­ PeerPolicyAttributes
        +­­ VrfAttributes
              +­­ AddressFamilyAttributes
which will dictate how the build_config method renders the corresponding configuration.
For example, lets define bgp conf object like this:
from genie.libs.conf.bgp.bgp import Bgp
b1 = Bgp(asn='65876')
How can I assign vrf ID and neighbors within that VRF for the object b1?
Thank you
Geevarghese Cheria
Appologies for the delay in responding to you. Request to check this repo -https://developer.cisco.com/codeexchange/github/repo/sttrayno/pyATS-Lab-Guide
