"dataProcessor: 'force'" not working for nodeSets
mspoerr
Level 4
Level 4
it seems that "dataProcessor: 'force'" property is not working for nodeSets -> all nodeSets are at the same position. is there an alternative?
Mathias
aaikepae
Hi Mathias,
nodeSet will not involved in the force layout process. If you want to set/get a position to a nodeSet. You can use vertexPositionSetter/vertexPositionGetter to achieve that.
I made a example, for the nodeSet, use the first node's position as its position. You can modify this base on your real use case.
http://jsfiddle.net/nextsupport/4Lr3kuos/
Abu
aaikepae
Hi Mathias,
Abu
Hi Abu,
Thank you very much!
Mathias
