Read sample with pretty print
saalvare
Nathan writes:
Is here a sample of a read operation with something equivalent to a pretty print of the configuration that has been read?
Many thanks
Nathan
You can use the CRUD service in combination with the codec service to pprint the configuration you read.  You can find an OC-BGP example using YDK 0.5.0 (or later ) at:
oc-bgp-20-ydk.py · GitHub
Down the road, you can expect the codec service to support other encodings (e.g. JSON, GPB, YAML, etc).
0 Replies 0
