Sample apps for Telemetry using OC/gNMI
deom
Related image
Hi Community,
I just brought another set of sample apps which configures OpenConfig Telemetry using the gNMI provider and the CRUD service.
This set of sample apps include four boilerplates and three custom apps. You can find the detailed information for each app in the below section.
gn-create-oc-telemetry-10-ydk.py - create boilerplate
gn-create-oc-telemetry-30-ydk.py - dialin single sensor-group/subscription
gn-create-oc-telemetry-32-ydk.py - dialin multiple sensor-paths
gn-create-oc-telemetry-34-ydk.py - dialin multiple sensor-groups
gn-delete-oc-telemetry-10-ydk.py - delete boilerplate
gn-delete-oc-telemetry-20-ydk.py - delete all telemetry config
gn-read-oc-telemetry-10-ydk.py - read boilerplate
gn-update-oc-telemetry-10-ydk.py - update boilerplate
If you are interested in CLI configuration, JSON files, and all of the python files for the Telemetry sample apps of OpenConfig/gNMI, check out the following link: https://github.com/CiscoDevNet/ydk-py-samples/tree/oc-telemetry/samples/basic/crud/gnmi/models/openconfig/openconfig-telemetry
Have Fun! 😄
0 Replies 0
