Sample apps for XR DNS using CRUD/gNMI
deom1
Hi Community,
I have added a new set of sample applications which configure domain for XR data model using the CRUD service and the gNMI provider.
This set includes four boilerplate applications and fourteen custom applications as follows:
gn-create-xr-ip-domain-cfg-10-ydk.py - create boilerplate
gn-create-xr-ip-domain-cfg-20-ydk.py - static (local) hosts
gn-create-xr-ip-domain-cfg-21-ydk.py - static (local) IPv6 hosts
gn-create-xr-ip-domain-cfg-22-ydk.py - single domain, various servers
gn-create-xr-ip-domain-cfg-23-ydk.py - single domain, various IPv6 servers
gn-create-xr-ip-domain-cfg-24-ydk.py - various domains, various srvs
gn-create-xr-ip-domain-cfg-25-ydk.py - various domains, various IPv6 srvs
gn-create-xr-ip-domain-cfg-30-ydk.py - static (local) hosts / VRF
gn-create-xr-ip-domain-cfg-31-ydk.py - VRF-aware static (local) IPv6 hosts
gn-create-xr-ip-domain-cfg-32-ydk.py - single domain, various srvs / VRF
gn-create-xr-ip-domain-cfg-33-ydk.py - VRF/ single dom, various IPv6 srvs
gn-create-xr-ip-domain-cfg-34-ydk.py - various domains, various srvs/VRF
gn-create-xr-ip-domain-cfg-35-ydk.py - VRF/ various domains/IPv6 servers
gn-create-xr-ip-domain-cfg-40-ydk.py - disable domain lookup
gn-delete-xr-ip-domain-cfg-10-ydk.py - delete boilerplate
gn-delete-xr-ip-domain-cfg-20-ydk.py - delete all domain configuration
gn-read-xr-ip-domain-cfg-10-ydk.py   - read boilerplate
gn-update-xr-ip-domain-cfg-10-ydk.py - update boilerplate
 The following link will direct you to the Github repository page containing all the python apps, CLI files, and JSON files:
https://github.com/CiscoDevNet/ydk-py-samples/tree/master/samples/basic/crud/gnmi/models/cisco-ios-xr/Cisco-IOS-XR-ip-domain-cfg
Enjoy!
0 Replies 0
