Sample apps for XR NTP using CRUD/gNMI
deom1
Hello Community,
New sample applications have arrived!
These sample applications include four boilerplate applications and seven custom applications to configure NTP for XR data model using the CRUD service and the gNMI provider.
gn-create-xr-ip-ntp-cfg-10-ydk.py - create boilerplate
gn-create-xr-ip-ntp-cfg-20-ydk.py - IPv4 server
gn-create-xr-ip-ntp-cfg-21-ydk.py - IPv6 server
gn-create-xr-ip-ntp-cfg-22-ydk.py - IPv4 server w/source intf
gn-create-xr-ip-ntp-cfg-23-ydk.py - IPv6 server w/source intf
gn-create-xr-ip-ntp-cfg-24-ydk.py - VRF-aware NTPv4 with iburst
gn-create-xr-ip-ntp-cfg-25-ydk.py - VRF-aware NTPv6 with iburst
gn-delete-xr-ip-ntp-cfg-10-ydk.py - delete boilerplate
gn-delete-xr-ip-ntp-cfg-20-ydk.py - delete all IPv6 NTP configuration
gn-read-xr-ip-ntp-cfg-10-ydk.py   - read boilerplate
gn-update-xr-ip-ntp-cfg-10-ydk.py - update boilerplate
 You can find the python files, CLI files, and JSON files in the following CiscoDevNet Github repository:
https://github.com/CiscoDevNet/ydk-py-samples/tree/master/samples/basic/crud/gnmi/models/cisco-ios-xr/Cisco-IOS-XR-ip-ntp-cfg
Have fun!
0 Replies 0
