Sample apps for XR OSPFv2 using CRUD/gNMI
deom
Hello YDK folk,
I would like to introduce a new set of sample apps for ipv4 Open Shortest Path First version 2 (OSPFv2) configuration for XR using the gNMI provider and the CRUD service.
This set of OSPFv2 sample apps includes four boilerplate apps and five custom apps to configure OSPF (single- and inter-area routing):
gn-create-xr-ipv4-ospf-cfg-10-ydk.py - create boilerplate
gn-create-xr-ipv4-ospf-cfg-20-ydk.py - single-area IPv4 routing
gn-create-xr-ipv4-ospf-cfg-30-ydk.py - IPv4 ABR
gn-create-xr-ipv4-ospf-cfg-32-ydk.py - IPv4 ABR with stub area
gn-create-xr-ipv4-ospf-cfg-34-ydk.py - IPv4 ABR with totally stub area
gn-delete-xr-ipv4-ospf-cfg-10-ydk.py - delete boilerplate
gn-delete-xr-ipv4-ospf-cfg-20-ydk.py - delete all OSPFv2 config
gn-read-xr-ipv4-ospf-cfg-10-ydk.py   - read boilerplate
gn-update-xr-ipv4-ospf-cfg-10-ydk.py - update boilerplate
If you want to check out CLI configuration, JSON files, and all of the python files for XR ipv4 OSPFv2 sample applications, please visit the following link:
https://github.com/CiscoDevNet/ydk-py-samples/blob/master/samples/basic/crud/gnmi/models/cisco-ios-xr/Cisco-IOS-XR-ipv4-ospf-cfg
Give it a try!! :D
0 Replies 0
