topology parent container dimensions
jawalke2
Hi there,
I keep getting a console warning 'Please set height*width to topology's parent container'; my code is based on the dynamic topology example in the example github repo that's been posted on here.
I've set CSS height & width for the parent element that I'm passing in through app.container() but that doesn't appear to address this - can someone suggest what I need to do to fix this?
James
alzverev
Hi James,
You seem to be using an adaptive layout, which means that you want topology's container (for example <div class="next-app"></div>) to fit in parent container. It seems like NeXt can only deal with explicitly defined width and height of the parent container. I might advise you to set the dimensions manually.
Also, would be nice if you share your code so that I could inspect it and tell you how to address that
- Alex
jawalke2
so I have a bootstrap app, i define a container div:
<div id="next-app-container"></div>
I have some CSS:
#next-app-container {
  display: block ;
  height: 500px;
  width: 700px;
and my javascript in onload() includes:
var app = new nx.ui.Application();
  /* TopologyContainer is a nx.ui.Component object that can contain much more things than just a nx.graphic.Topology object.
  We can 'inject' a topology instance inside and interact with it easily
  var topologyContainer = new TopologyContainer();
  // topology instance was made in TopologyContainer, but we can invoke its members through 'topology' variable for convenience
  var topology = topologyContainer.topology();
  var actionBar = new ActionBar();
  //assign the app to the <div>
  var parent = document.getElementById('next-app-container') ;
  app.container(parent);
  // pass topology's instance into action's bar instance
  actionBar.assignTopology(topology);
  actionBar.attach(app);
  topology.attach(app);
pretty much lifted directly form some of the code examples for dynamic topology & custom tooltips...
when you say ' I might advise you to set the dimensions manually' I assume you mean via CSS as I have tried?!
Thanks for your response,
James
lkang2
In the next-modules/topology.js, you manually set the width/height of the topology, so the 'adaptive' property should be false.
Thanks; this fixed the warnings.
