Unable to start traffic unless specified force start when packet capture enabled in service mode
Hi Team,
I've observed that when we enable the service mode prior to packet capture, we're not able to start the traffic in normal mode unless we force start the ports for inducing the traffic.
>>> rs = t.set_service_mode(ports = 1, enabled=True)
>>> capture = t.start_capture(rx_ports = 1, limit = 100, mode = 'fixed', bpf_filter='ether src 00:00:00:71:00:01')
>>> t.clear_stats(my_ports)
>>> t.start(ports=my_ports, mult='100mbps', duration=10)
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/auto/cenbu/dev-test/ATS_python/regression/Iotssg/lib/trex_client/stl/trex_stl_lib/trex_stl_client.py", line 1208, in wrap2
    ret = f(*args, **kwargs)
  File "/auto/cenbu/dev-test/ATS_python/regression/Iotssg/lib/trex_client/stl/trex_stl_lib/trex_stl_client.py", line 2765, in start
    ports = self.__pre_start_check('START', ports, force)
  File "/auto/cenbu/dev-test/ATS_python/regression/Iotssg/lib/trex_client/stl/trex_stl_lib/trex_stl_client.py", line 2709, in __pre_start_check
    return self.psv.validate(cmd_name, ports, states)
  File "/auto/cenbu/dev-test/ATS_python/regression/Iotssg/lib/trex_client/stl/trex_stl_lib/trex_stl_psv.py", line 152, in validate
    self.validators[state].validate(self.client, cmd_name, ports, err_msg)
  File "/auto/cenbu/dev-test/ATS_python/regression/Iotssg/lib/trex_client/stl/trex_stl_lib/trex_stl_psv.py", line 29, in validate
    raise STLError('{0} - port(s) {1}: {2}'.format(cmd_name, invalid_ports, err_msg))
trex_stl_lib.trex_stl_exceptions.STLError: START - port(s) [1]: cannot be under service mode - please disable service mode or specify 'force'
>>> t.start(ports=my_ports, mult='100mbps', duration=10,force=True)
<trex_stl_lib.trex_stl_types.RC object at 0xf3f7256c>
>>> t.stop_capture(capture['id'],'/auto/cenbu/dev-test/ATS_python/dummy_asp.pcap')
>>> rs = t.set_service_mode(ports = 1, enabled=False)
Anurag
hhaim@cisco.com
This is by design. We don’t want you to forget that you are in service mode and performance is impacted
Hanoh
