using YDK unable to get output from cisco NCS5500 router
HI ,
Using YDK  , unable to get operational data from Cisco NCS 5500 router .
Error output
  File "test7.py", line 29, in <module>
    print("cpu util" is " +str(Cpu_util.total_cpu_one_minute))
AttributeError: 'YList' object has no attribute 'total_cpu_one_minute'
cpu util Script
from ydk.services import CRUDService,CodecService
from ydk.providers import NetconfServiceProvider,CodecServiceProvider
from ydk.models.cisco_ios_xr import Cisco_IOS_XR_shellutil_oper \
as xr_shellutil_oper
from ydk.models.cisco_ios_xr import Cisco_IOS_XR_wdsysmon_fd_oper \
as xr_wd_oper
from datetime import timedelta
if __name__ == "__main__":
    """Main execution path"""
# create NETCONF session
provider = NetconfServiceProvider(address="192.168.30.167",
                                  username="fabtool",
                                  password="NatRas@321",
                                  protocol="ssh")
# create CRUD service
crud = CRUDService()
# create system time object
system_time = xr_wd_oper.SystemMonitoring.CpuUtilization()
print system_time.total_cpu_one_minute
Cpu_util= crud.read(provider, system_time,only_config=False)
print("Cpu util is " +str(Cpu_util.total_cpu_one_minute))
Kindly do the needful for resolution.
Jay
einarnn
Jay,
When you query the system monitoring subtree, the result you get back is not a simple scalar value. If you look at the YANG tree for the schema:
module: Cisco-IOS-XR-wdsysmon-fd-oper
+--ro system-monitoring
+--ro cpu-utilization*
+--ro node-name xr:Node-id
+--ro total-cpu-one-minute? uint32
+--ro total-cpu-five-minute? uint32
+--ro total-cpu-fifteen-minute? uint32
+--ro process-cpu*
+--ro process-name? string
+--ro process-id? uint32
+--ro process-cpu-one-minute? uint32
+--ro process-cpu-five-minute? uint32
+--ro process-cpu-fifteen-minute? uint32
This means that your print statement:
…is just wrong. The error message ("AttributeError: 'YList' object has no attribute ‘total_cpu_one_minute’”) is also pointing this out to you. The CPU utilisation is a list entries, keyed by the node_name. Please try iterating over the return data. For example:
for c in Cpu_util:
print(‘Node %s one-minute CPU utilization is %d’ % (c.node_name, c.total_cpu_one_minute))
I haven’t tested this code, so it may not be 100% correct!
Cheers,
Einar
einarnn
Jay,
+--ro process-cpu*
for c in Cpu_util:
Cheers,
Einar
To add to Einar's response, you want to look at the documentation for the model.  In particular, you'll see that 'cpu_utilization' is a list and 'node_name' acts as key:
https://goo.gl/LJMZGQ
HTH.
