VIRL - ISIS Interconnect between XRv and IOSv
willf0001
I'm having trouble establishing an IS-IS adjacency between IOSv and XRv routers in VIRL. I can see the ISIS neighbor from the IOSv box, but not from the XRv box. From what I can tell in the debugs it's as if the XRv box is not receiving the adjacency packets from the IOSv box.
XRv = CR01
IOSv = DR01
This is a simple point to point interconnect with a /31 between the two.
DR01 Gi0/1  <--->  CR01 Gi0/0/0/1
DR01 Config
interface GigabitEthernet0/1
description [CR01][Gi0/0/0/1] CORE ROUTER CONNECTION
mtu 9000
ip address 62.159.216.129 255.255.255.254
no ip redirects
no ip proxy-arp
ip router isis 1
duplex auto
speed auto
media-type rj45
isis circuit-type level-2-only
isis network point-to-point
isis hello-interval 1
isis csnp-interval 10
router isis 1
net 00.0621.5921.6104.00
is-type level-2-only
ispf level-2
metric-style wide
fast-flood 10
max-lsp-lifetime 65535
lsp-refresh-interval 65000
spf-interval 10 50 20
prc-interval 10 50 20
lsp-gen-interval 5 50 20
passive-interface Loopback0
CR01 Config
interface GigabitEthernet0/0/0/1
description [Gi0/1] DR01
mtu 9000
ipv4 address 62.159.216.128 255.255.255.254
router isis 1
net 00.0621.5921.6100.0
nsf cisco
log adjacency changes
lsp-gen-interval maximum-wait 5000 initial-wait 50 secondary-wait 20
address-family ipv4 unicast
  metric-style wide
  ispf level 2
  spf-interval maximum-wait 10000 initial-wait 50 secondary-wait 20
  point-to-point
  csnp-interval 10
  hello-padding disable
  hello-interval 1
   mpls ldp sync level 2
DR01#show isis neighbors
Tag 1:
System Id       Type Interface     IP Address      State Holdtime Circuit Id
0621.5921.6100  L2   Gi0/1         62.159.216.128  INIT  2        00
RP/0/0/CPU0:CR01#show isis neighbors
Tue Jun  7 18:02:37.401 UTC
IS-IS 1 neighbors:
System Id      Interface        SNPA           State Holdtime Type IETF-NSF
DR02      Gi0/0/0/2        *PtoP*         Up    2        L2   Capable
Total neighbor count: 1
Note the missing DR01 from the neighbor table. Any help is appreciated, I am new to IS-IS just trying to learn.
Geevarghese Cheria
Hi Will,
   Iam trying to give  a general config explanation . Please check if you find  helpful.
I think you have not set the nsap-address in your DR01 Config only CRO1 its there. Its like you need to do the same on both routers the same step..
Router(config)#router isis
Router(config-router)#net <nasp-address>..
I think its level 1. that is as there is only one area.. Can you try with level-1 (Not sure)
Router(config-router)#is-type level -1
now you may go to which all are the interfaces that you need to configure  and type like..
Router(config-router)#int lo0
Router(config-if)#ip router isis
Next step is for authentication got to both routers and give
#router isis
#area-password <passwd>
If there is more than one are then need to give
#domain-password<passwd>
Thanks and Regards,
Geevarghese
