Yangsuite Python Code from RestConf
Haydenuff
Community Member
When attempting to use Yangsuite configured with Restconf I am able to interrogate my Cat8KV running IOS-XE successfully.
When navigating to Protocols > RESTCONFG > (Specifying details) > Replays > Generate Python Script nothing happens. The ansible option seems to function as expected but not the python.
I've attempted to carry out an request from the router after clicking Generate API's and then use the Generate Python Script button as well but this doesn't do anything either.
Could I please get some assistance in the proper use of this? I've looked at the documentation and the button doesn't even show on the manual, it only mentions Python scripts for NETCONF.
@Haydenuff suggest to open an issue with details on the repo https://github.com/CiscoDevNet/yangsuite/issues
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Haydenuff
Community Member
Bump
Hope this helps.
Thanks for the reply and direction I'll get on that now. Have a great day.
