YDK issue (possible bug in XR?)
brfoster
Trying to run a sample script against XRv 6.0.1
RP/0/0/CPU0:iosxrv-1#show version
Thu Jul 14 18:49:06.322 UTC
Cisco IOS XR Software, Version 6.0.1[Default]
Copyright (c) 2016 by Cisco Systems, Inc.
ROM: GRUB, Version 1.99(0), DEV RELEASE
iosxrv-1 uptime is 2 days, 1 hour, 34 minutes
Script is attached.  When I run it I see uptime is not coming correctly from XR, see attached log for details.
Should we file a bug against XR or is this already a known bug?
Tracked under CSCva50442
5 Replies 5
saalvare
Do you see the uptime increment?  Is there a constant offset between what the app reads and what the CLI displays?
No, it’s always a small number between 1 and 3 seconds. I just ran it several times.
Seeing same issue on my test bed.  Thanks for bring it up.  Will file an XR defect if one doesn't exist already.
2016-07-15 08:49:48,712 - ydk.providers.NetconfServiceProvider - DEBUG -
<?xml version="1.0"?>
<rpc-reply message-id="urn:uuid:c28bd8f8-4aa3-11e6-9e23-081196796e8c" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<data>
  <system-time xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-shellutil-oper">
  <clock>
    <year>2016</year>
    <month>7</month>
    <day>15</day>
    <hour>7</hour>
    <minute>34</minute>
    <second>43</second>
    <millisecond>974</millisecond>
    <wday>5</wday>
    <time-zone>UTC</time-zone>
    <time-source>calendar</time-source>
  </clock>
  <uptime>
    <host-name>carreras</host-name>
    <uptime>1</uptime>
  </uptime>
  </system-time>
</data>
</rpc-reply>
Fix should be released in 6.1.2.
