YDK path repository issue with OpenDayLight
voxnetwork
Hi All,
I'm trying a simple python script based on the YDK module to send some BGP configuration to ODL.
I've based my script on the example found in core/samples/path_odl_bgp.py and bgp_xr_opendaylight.py.
But when I run my script I got the following error:
Traceback (most recent call last):
File "obgp.py", line 21, in <module>
odl_provider = OpenDaylightServiceProvider(repo, "127.0.0.1", "admin", "admin", 8181, EncodingFormat.XML)
ValueError: type must be string, but is object
Here's the full script:
import os
import sys
from argparse import ArgumentParser
from ydk.types import Empty
from ydk.services import CRUDService
from ydk.providers import OpenDaylightServiceProvider
from ydk.errors import YError
from ydk.types import EncodingFormat
from ydk.models.openconfig.openconfig_bgp import Bgp
from ydk.models.cisco_ios_xe.Cisco_IOS_XE_native import Native
from ydk.path import Repository
repo = Repository("/opt/karaf-0.8.3/cache/schema") # In this case, we have a ODL boron instance with this schema cache location
bgp = openconfig_bgp.Bgp()
bgp.global_.config.as_ = 65023
crud_service = CRUDService()
crud_service.create(provider.get_node_provider('1681'), bgp)
odl_run(crud_service, provider)
I can't figure out what's wrong with the repository path.
Any help appreciated.
Benjamin
6 Replies 6
abhirame
I cannot reproduce this issue. Your code is working fine for me. My env:
$ pip list|grep ydk
ydk                     0.7.2
Thanks for your check.
Here's my env:
root@odl-01-501:/opt/netapps# pip list | grep ydk
ydk (0.7.2)
ydk-models-cisco-ios-xe (16.8.1.post1)
ydk-models-ietf (0.1.5.post1)
ydk-models-openconfig (0.1.5)
Anything which would cause conflict ?
If not then I'll spawn a new VM and retry from a clean install.
Benjamin
Any luck with your new VM?
Unfortunately I got the same error with a new VM:
root@odl-02-501:/opt# python obgp.py
  File "obgp.py", line 28, in <module>
    odl_provider = OpenDaylightServiceProvider(repo , "127.0.0.1" , "admin" , "admin" , 8181 , EncodingFormat.XML)
I'm using Python 2.7.12 , I'll give it a try with python3.x anytime soon.
Benjamin
Hi Abhirame,
Would you be able to tell me if YDK 0.8.4 is working with ODL 0.11.1 ?
I got a little bit further in the troubleshooting and it seems that YDK doesn't like the answer it receives from ODL.
I can see that the connection is triggered (thanks to tshark) with:
but for some reason when the replies come back from the ODL python output:
File "<stdin>", line 1, in <module>
So I'd be interested to know if YDK 0.8.4 has been tested with ODL version > 5.2(Boron)
Found out that when my device is in "connecting" state with my controller it's actually not complaining
opendaylight-user@root>netconf:list-devices
NETCONF ID          | NETCONF IP   | NETCONF Port | Status
EDG-01-216.BRU1-IXN | 10.1.128.120 | 1830         | connecting
>>> odl_provider = OpenDaylightServiceProvider(repo, "10.1.20.144", "admin", "admin", 8181, EncodingFormat.XML)
but as soon as the device is connected, then it fails:
EDG-01-216.BRU1-IXN | 10.1.128.120 | 1830         | connected
Below the output from a curl call just like YDK seems to be doing when it's working (for YDK):
~$ curl http://admin:admin@10.1.20.144:8181/restconf/operational/network-topology:network-topology/ | jq ''
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   246    0   246    0     0   1200      0 --:--:-- --:--:-- --:--:--  1200
  "network-topology": {
    "topology": [
        "topology-id": "topology-netconf",
        "node": [
            "node-id": "EDG-01-216.BRU1-IXN",
            "netconf-node-topology:host": "10.1.128.120",
            "netconf-node-topology:connection-status": "connecting",
            "netconf-node-topology:port": 1830
Below the output from a curl call just like YDK seems to be doing when it's not working (for YDK):
100 64061    0 64061    0     0  45954      0 --:--:--  0:00:01 --:--:-- 45921
    "topology": [
        "node": [
            "netconf-node-topology:unavailable-capabilities": {
              "unavailable-capability": [
                  "capability": "(http://cisco.com/ns/cisco-xe-ietf-ospf-deviation?revision=2018-02-09)cisco-xe-ietf-ospf-deviation",
                  "failure-reason": "unable-to-resolve"
            "netconf-node-topology:available-capabilities": {
              "available-capability": [
                  "capability-origin": "device-advertised",
                  "capability": "urn:ietf:params:netconf:capability:notification:1.1"
                  "capability": "urn:ietf:params:netconf:capability:with-defaults:1.0?basic-mode=explicit&also-supported=report-all-tagged"
                  "capability": "urn:ietf:params:netconf:capability:notification:1.0"
                  "capability": "urn:ietf:params:netconf:base:1.0"
                  "capability": "urn:ietf:params:netconf:capability:yang-library:1.0?revision=2016-06-21&module-set-id=88c694c75e847aba17e8ab19254ad090"
                  "capability": "http://tail-f.com/ns/netconf/actions/1.0"
                  "capability": "urn:ietf:params:netconf:capability:validate:1.1"
                  "capability": "urn:ietf:params:netconf:capability:validate:1.0"
                  "capability": "urn:ietf:params:netconf:base:1.1"
                  "capability": "urn:ietf:params:netconf:capability:interleave:1.0"
                  "capability": "urn:ietf:params:netconf:capability:rollback-on-error:1.0"
                  "capability": "urn:ietf:params:netconf:capability:xpath:1.0"
                  "capability": "http://tail-f.com/ns/netconf/extensions"
