Create a workflow witht the same inputs as the first task
borisaelen
Hi All,
I want to create a workflow for one specific task. In this case it's the Create N7K VDC task.
This task has all kind of wonderful inputs and smart LOV's and input fields that change when I select something in the previous drop down menu.
Now I would like my workflow to have exactly the same kind of Input fields with the same intelligence.
Obviously I don't want to make everything myself in the Workflow or with Custom Workflow Inputs.
Can anyway let me know if it is possible to tell the Workflow to use the Inputs from the first or only task in that workflow?
Kind Regards,
Boris Aelen
Orf Gelbrich
the only thing I can offer up is look at every LOV (CTRL-F LOV) on this site...
https://communities.cisco.com/docs/DOC-56419
UCSD List of Value (LOV) Tutorial (Multi Select Check Box LOV from CSV file)
Cisco UCS X-Series Energy Efficiency Offer
