Return Objects From UCS Director To My Web Site Using API
Rami_13
I want to send many objects from UCS Director (Workflow or Custom Workflow Tasks) to my web Site ( Lang PHP).
I tested this request from Rest Client (ARC), but the returned result is ==> "serviceresult: 600" (this is the service request number).
I would like to retrieve the data on the same request, for exemple after invoking Worflow "Proviosnning VM Vmware", I want to recover the data ( like ip address, Vm Name, ...) so i can store in my database.
Thx,
Rami Khili
7 Replies 7
Orf Gelbrich
If I understand you correctly you want to retrieve the information per SR _ID.
Show a list of SRs:
http://10.52.249.103/app/api/rest?opName=userAPIGetServiceRequests&opData=
1. {
2. "Service_Request_ID": 115,
3. "Request_Type": "Create VM",
4. "Initiating_User": "demouser",
5. "Group": "DemoGroup",
6. "Catalog_Workflow_Name": "Provision VMware VM",
7. "Initiator_Comments": "",
8. "Request_Time": "Sep 10, 2014 09:39:49 UTC",
9. "Request_Status": "Failed",
10. "Rollback_Type": "",
11. "Catalog": "No"
12. },
Get details of an individual SR:
http://10.52.249.103/app/api/rest?opName=userAPIGetServiceRequestDetails&opData=
1. {
2. "serviceResult":
3. {
4. "requestId": 115,
5. "requestType": 0,
6. "initiatingUser": "demouser",
7. "groupName": "DemoGroup",
8. "requestTime": 1410341989314,
9. "comments": "",
10. "provisionQuantity": 1,
11. "provisionCatalog": "Windows 2008 R2",
12. "provisionVDCName": "CUIC-DEPLOYED-02",
13. "provisionDurationHours": -1
14. },
15. "serviceError": null,
16. "serviceName": "InfraMgr",
17. "opName": "userAPIGetServiceRequestDetails"
18. }
Get SR log:
http://10.52.249.103/app/api/rest?opName=userAPIGetServiceRequestWorkFlow&opData=
1. {
2. "stepId": "Initiated by demouser",
3. "executionStatus": 3,
4. "statusMessage": null,
5. "handlerId": 4,
6. "startedTime": -1,
7. "completedTime": 1410341983118,
8. "validTill": -1,
9. "startAfter": -1
10. },
11. {
12. "stepId": "VM Provision Inputs",
13. "executionStatus": 3,
14. "statusMessage": "",
15. "handlerId": 12,
16. "startedTime": -1,
17. "completedTime": 1410341989488,
18. "validTill": -1,
19. "startAfter": -1
20. },
21. {
22. "stepId": "Budget Allocation",
23. "executionStatus": 3,
24. "statusMessage": "Budget watch is not requested by the group.",
25. "handlerId": 12,
26. "startedTime": -1,
27. "completedTime": 1410341995265,
28. "validTill": -1,
29. "startAfter": -1
30. },
Thank you, but when i execute this simple exepmle :
loadLibrary("JSON-JS-Module/JSON-JS-ModuleLibrary");
importPackage(com.cloupia.model.cIM);
importPackage(java.util);
importPackage(java.lang);
importPackage(com.cloupia.service.cIM.inframgr);
importPackage(com.cloupia.lib.util);
var test = "{'name':'1'}";
var resultObj = JSON2.parse(test);
logger.addInfo("result= "+resultObj );
output.return_a = resultObj;
I got this error:
"serviceResponse": null
"serviceError": "REMOTE_SERVICE_EXCEPTION: The JsonDeserializer IntegerTypeAdapter failed to deserialized json object "return_test" given the type int"
I want to retrieve resultObj.
Take a look at this posting
https://communities.cisco.com/docs/DOC-58243
Hi Gelbrich,
Thank you for your answer,
I followed the link, but I have no return ( jsonData ) from ucs director. !! he only returns SR in the "serviceResult"
"serviceResult": 685
"opName": "userAPISubmitWorkflowServiceRequest"
what is the function in opname ? userAPIGetWorkflowServiceRequest, userAPISubmitWorkflowServiceRequest, ??
here is my code:
Code 1:
var jsonData = '{"pool":"test-http-pool","description":"My test virtual server","name":"test-http-virtual","mask":"255.255.255.255","profiles":[{"name":"http","kind":"ltm:virtual:profile"},{"name":"tcp","kind":"ltm:virtual:profile"}],"ipProtocol":"tcp","sourceAddressTranslation":{"type":"automap"},"kind":"tm:ltm:virtual:virtualstate","destination":"1.1.1.3:80"}';
var data = JSON.getJsonElement(jsonData,null);
Code 2 :
var map = new HashMap ();
map.put ("nom", "test-http-virtual");
var data = JSON.javaToJsonString (carte, map.getClass ());
I need to recover the variable jsonData
Thank you in advance
I just ran this…
https://172.16.50.51/app/api/rest?opName=userAPIGetServiceRequestWorkFlow&opData=
And the result was this:
{ "serviceResult":{"requestId":3330,"workflowCreated":1530201600207,"submittedTime":1530201600530,"cancelledTime":-1,"cancelledByUser":null,"adminStatus":1,"executionStatus":3,"futureStartTime":1530201600207,"entries":[{"stepId":"Initiated by admin","executionStatus":3,"statusMessage":null,"handlerId":4,"startedTime":-1,"completedTime":1530201603658,"validTill":-1,"startAfter":-1},{"stepId":"RESTfulwebServiceAccess","executionStatus":3,"statusMessage":"","handlerId":12,"startedTime":-1,"completedTime":1530201607831,"validTill":-1,"startAfter":-1},{"stepId":"Parse_Temp","executionStatus":3,"statusMessage":"","handlerId":12,"startedTime":-1,"completedTime":1530201610050,"validTill":-1,"startAfter":-1},{"stepId":"kelvin_to_fahrenheit","executionStatus":3,"statusMessage":"","handlerId":12,"startedTime":-1,"completedTime":1530201616094,"validTill":-1,"startAfter":-1},{"stepId":"Child workflow (GlobalVariables_UPDATE_put_API_Global_var)","executionStatus":3,"statusMessage":"Completed action","handlerId":12,"startedTime":-1,"completedTime":1530201642451,"validTill":-1,"startAfter":-1},{"stepId":"Complete","executionStatus":3,"statusMessage":"Completed successfully.","handlerId":13,"startedTime":-1,"completedTime":1530201642833,"validTill":-1,"startAfter":-1}]}, "serviceError":null, "serviceName":"InfraMgr", "opName":"userAPIGetServiceRequestWorkFlow" }
1) In your request you have invoked the workflow first then you have retrieved the workflow data ===> I need to invoke the workflow and retrieve the data at the same time
2) The data in serviceResult is information about the workflow and this is not the case ==> I need the output of the workflow in serviceResult
Invoking workflow and getting information on the running workflow would be two separate events.
Infact the checking for workflow status would probably be in a loop with a wait status (~20sec) to see the status of the workflow.
When evoking a workflow it will only return the SR_ID nothing more.
https://communities.cisco.com/docs/DOC-55973
The SR ID is returned and with that number you would have to make further API calls to see status.
Cisco UCS X-Series Energy Efficiency Offer
