hherring
Task NameAdd Disk to VM Same Datastore
Description
Prerequisites
Tested on 5.4
CategoryWorkflow
ComponentsvSphere 5.x
User InputsVM, DiskSizeGb
  8. Click "Submit".
Workflow Name:
Workflow:
Input Variables:
Importing with Custom Tasks:
VM in vCenter Before:
VM in vCenter After:
Anuj Modi
The workflow is missing from the doc.
Anuj
hherring
Workflow attached. Thanks Anuj!
hherring
Only supports VMs using a single datastore. Will update with improved version that uese "best" datastore VM currently connected to.
