Orf Gelbrich
Task Name
File Upload
Description
Prerequisites
  1. Tested on 5.4 beta
  2. Tested on UCSD 6.0 (see side notes)
  3. Tested on 6.0.1.1 this does not work (bug is filed)
  4. This is part of UCSD 6.5 Alpha and I have tested it.
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  1. userid to change to
OutputInstructions for Regular Workflow Use:
  8. Click "Submit".
Please remember there is a security aspect to this posting!
Steps:
1      Extract the zip file and upload the jar to /opt/infra/inframgr
2       Edit run.sh and update the class path with the jar name ‘fileupload.jar’
[root@CUCSD_Primary inframgr]# cat run.sh
java -Xms4096m -Xmx4096m -XX:MaxPermSize=512m -Djava.security.manager -Djava.security.policy=security.policy -cp .:fileupload.jar:inframgr.jar:google-gson.jar:java-xmlbuilder-0.6.jar:vmguest.jar:vim25-wsdl.jar:vijava60compat.jar:vijava55b20130927.jar:ssoclient-wsdl.jar:srm.jar:pbm-wsdl.jar:jaxen-1.1-beta-6.jar:dom4j-1.6.1.jar:velocity-1.6.2.jar:velocity-1.6.2-dep.jar:jclouds-vcloud-1.0-beta-7.jar:jclouds-terremark-1.0-beta-7.jar:jclouds-scriptbuilder-1.0-SNAPSHOT.jar:jclouds-log4j-1.0-beta-7.jar:jclouds-jsch-1.0-beta-7.jar:jclouds-core-1.0-beta-7-jar-with-dependencies.jar:jclouds-compute-1.0-beta-7.jar:vcloud-java-sdk-1.5.0.jar:rest-api-schemas-1.5.0.jar:syslog4j-0.9.43-bin.jar:maverick-all.jar:slf4j-log4j12-1.7.6.jar:slf4j-api-1.7.6.jar:ss_css2.jar:pd4ml.jar:ojdbc14.jar:classes12.jar:manageontap.jar:mysql-connector-java-5.1.24-bin.jar:mongo-java-driver-2.11.3.jar:log4j-1.2.15.jar:jxl.jar:junit-4.9b2.jar:json-lib.jar:joda-time-1.6.jar:jfreechart-1.0.13.jar:jcommon-1.0.16.jar:smtp.jar:mailapi.jar:javassist.jar:jssc.jar:guava-15.0.jar:google-gson.jar:flexlm.jar:Vendor_info.jar:EccpressoAll.jar:ehcache-core-2.6.6.jar:aws-java-sdk-1.4.3.jar:jdo2-api-2.3-eb.jar:datanucleus-rdbms-3.0.0-release.jar:datanucleus-core-3.0.0-release.jar:datanucleus-cache-3.0.0-release.jar:datanucleus-api-jdo-3.0.0-release.jar:asm-3.1.jar:ucsd-rest-api-sdk-v2.jar:cuic-client.jar:bonecp-0.8.0.RELEASE.jar:servlet-api.jar:commons-validator-1.4.0.jar:commons-pool-1.6.jar:commons-pool-1.3.jar:commons-net-3.1.jar:commons-logging-1.1.jar:commons-lang-2.2.jar:commons-io-2.0.1.jar:commons-dbcp-1.4.jar:commons-configuration-1.3.jar:commons-compress-1.9.jar:commons-collections-3.2.jar:commons-logging-1.1.jar:httpmime-4.1.3.jar:httpcore-4.1.4.jar:httpclient-4.1.3.jar:commons-httpclient-3.1.jar:commons-codec-1.3.jar:commons-codec-1.7.jar:wsdl4j-1.5.1.jar:saaj.jar:jaxrpc.jar:commons-logging-1.0.4.jar:commons-discovery.jar:commons-discovery-0.2.jar:axis.jar:XmlSchema-1.4.3.jar:xalan.jar:commons-logging.jar:commons-httpclient-3.0.1.jar:commons-codec-1.3.jar:stax-api-1.0.jar:jaxb-api-2.0.jar:geronimo-jta_1.0.1B_spec-1.0.1.jar:geronimo-jms_1.1_spec-1.1.1.jar:geronimo-j2ee-management_1.0_spec-1.0.jar:commons-logging-1.1.jar:activemq-jaas-5.2.0.jar:activemq-core-5.2.0.jar:activation-1.1.jar:vision-api-2.5.3.0.jar:iControl.jar: com.cloupia.service.cIM.inframgr.InfraMgrMain $*
3       Restart UCSD
4       Execute the custom-workflow ‘RegisterFileUploadInputType’.
          It will register the new input type ‘file upload’. Use this type file uploading.
5       Execute the workflow ‘execute file upload’.
For UCSD 6.0 please place the fileupload.jad file into /opt/infra/inframgr/.
Then rename the file to:
          mv fileupload.jar patch-fileupload.jar
Restart UCSD application (shelladmin option 3 and 4)
Run the register workflow. (there is  now a check box to have the workflow execute on UCSD startup)
Note:
     all patch-<filename>.jar files are picked up automatically by inframgr.
Orf Gelbrich
It should and has before.
So does UCSd start up with the jar file in place?
eric.ostrom
Community Member
Orf-
Yes, it started up with the jar file in place.
I’m restarting again and will test shortly.
I know it’s probably out of the ordinary … but would it be possible to do a webex?
Sincerely,
-Eric
Orf Gelbrich
Not at all, except I am 30,000 feet in the air
I can do a webex on Monday.
Send me an e-mail ogelbric@cisco.com<mailto:ogelbric@cisco.com> and I can set it up.
Orf Gelbrich
Check out UCS Director Workflow INDEX<https://communities.cisco.com/docs/DOC-56419> on Cisco Communities Site (Twitter @UCSDGURU)
eric.ostrom
Community Member
Orf-
That’s great!
I’ve already sent the email for a webex reminder.
I’ll send a calendar invite as well.
Sincerely,
-Eric
jianguhu
Right now we are running UCS Director 6.5.0.0 build 65835.
Does this code work in 6.5?
I tried the fileupload.jar file into /opt/infra/inframgr/
and edited runprod.sh and update the class path with the jar name ‘fileupload.jar’.
when we run the "execute now" with any workflow, only  "Close" button shown
Orf Gelbrich
There is actually now a file up load variable built into UCSD.
NMagnano1
Hi Orf.
I'm able to upload the file, using the file upload variable. But then I dont know how to use the file.
It is stored at /opt/infra/uploads/myuser/tempfolder/file.ext
How can I tranfer the uploaded file to another linux server?
Thanks!
