kesimmon
Task Name
APIC API Command
Description
Send XML/JSON to Application Policy Infrastructure Controller
Prerequisites
Validated on UCSD 5.3.1.1
Category
Workflow Task
Components
Application Centric Infrastructure
User Inputs
  1. APIC IP
  2. APIC User
  3. APIC User Password
  4. Method (POST/GET)
  5. XML/JSON
Output
Result of operation
Date 05-SEP-2017: New Custom task uploaded which works both on HTTP and HTTPS. Tested and validated on UCSD 6.0.1.2 - by Phani Penmethsa
Summary
Provides custom task to send/retrieve information from an Application Centric Infrastructure Controller using XML or JSON.
Installation
  2. Unzip the file on your computer. Should end up with a .WFDX file.
  8. Click "Submit".
Usage
See attached document “UCS Director – APIC API Command”
The workflow also includes a sample Unit Test script that can be used to validate the custom task against different releases of UCS Director.
Also contains tips on finding APIC API calls.
Example
Use Post/Get operations to send/query the Application Policy Infrastructure Controller.
Orf Gelbrich
you may have to use a pre task (string combine) and built the line and then feed it to this place.
Orf Gelbrich
have you tried escaping the [ . like \]
just a suggestion
harishap.24
Tired in both ways but still facing same issue.
Orf Gelbrich
how / where can I test this
I guess you are saying then an set of square brackets is in the API call it will fail? yes?
Orf Gelbrich
take a look at this...
https://stackoverflow.com/questions/48949788/rest-url-request-and-square-brackets-and
you may need to do this . "["
harishap.24
The above two did
I tried these 2 method but no sucess, attached screenshots for the same.
   1. "[" -  using quotes for the square brackets
   2. using forward and backward slash.
To try this: Not sure if you would have an environment to try this, but below is the URI to fetch the properties of a single physical port of a node.
/api/node/mo/topology/pod-1/node-1005/sys/phys-[eth1/34].json
Orf Gelbrich
I assume you are talking to an APIC controller via API call?
Are you using a generic API call in UCSD 6.6.?
Orf Gelbrich
this works...
/api/node/mo/topology/pod-1/node-1005/sys/phys-%5Beth1/34%5D.json
Orf Gelbrich
Did this work for you?
Orf Gelbrich
%5B and %5D
harishap.24
Hi Orf;
Thanks for the inputs, After Replacing the square bracket with  %5B It is working fine.
Harish
