Orf Gelbrich
Task Name
VIX sample workflows
Description
Prerequisites
  1. Tested on 4.1.0.3b
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  1. User ID
  2. Password
  3. VIX command
Output
  8. Click "Submit".
Linux example script
#!/bin/sh
# script used by UCSD to change the hostname and IP of either a solaris
# or linux host.
# if 3 arguments are not passed to the script, exit
if [ $# != 3 ]; then
        echo "usage: /vix.sh <ip> <netmask> <gateway>"
        echo "arguments passed to vix.sh $1, $2, $3" > /vix.out
        exit
fi
# set variables to change server identity
HOSTNAME=`hostname | awk -F. '{print $1}'`
IP=$1
NETMASK=$2
GATEWAY=$3
# set parsed out variables
LOCATION=`echo $HOSTNAME | cut -c1-4`
NETWORK=`echo $IP | awk -F. '{print $1"."$2"."$3".0"}'`
OS=`uname -s`
# configure DNS
if [ $LOCATION == "vacu" ]; then
        echo "search nss.abc.com dce.isa.abc.com hosts.abc.com" > /etc/resolv.conf
        echo "nameserver 10.80.18.21" >> /etc/resolv.conf
        echo "nameserver 10.94.89.14" >> /etc/resolv.conf
        echo "nameserver 10.36.115.31" >> /etc/resolv.conf
elif [ $LOCATION == "casc" ]; then
        echo "search nss.abc.com dcw.isa.abc.com hosts.abc.com" > /etc/resolv.conf
        echo "nameserver 10.25.136.41" >> /etc/resolv.conf
        echo "nameserver 10.15.210.31" >> /etc/resolv.conf
        echo "nameserver 10.14.8.34" >> /etc/resolv.conf
fi
if [ "$OS" == "SunOS" ]; then
# change crash directory name
rm -rf /var/crash/*
mkdir /var/crash/$HOSTNAME
chmod 700 /var/crash/$HOSTNAME
dumpadm -s /var/crash/$HOSTNAME
# change hostname in /etc/hosts
#echo "#" > /etc/hosts
#echo "# Internet host table" >> /etc/hosts
#echo "#" >> /etc/hosts
#echo "::1     localhost" >> /etc/hosts
#echo "127.0.0.1       localhost" >> /etc/hosts
#echo "$IP      ${HOSTNAME}.nss.abc.com      $HOSTNAME" >> /etc/hosts
sed '/192.168.254/d' /etc/hosts > /tmp/hosts
cp /tmp/hosts /etc/hosts
# change nodename
echo $HOSTNAME > /etc/nodename
# change interface
echo $HOSTNAME > /etc/hostname.e1000g0
# change netmask
grep '^#' /etc/netmasks > /tmp/netmasks
cp /tmp/netmasks /etc/netmasks
echo "$NETWORK  $NETMASK" >> /etc/netmasks
# change gateway
echo $GATEWAY > /etc/defaultrouter
# clean up
rm -rf /.ssh/*
rm -rf /.bash_history
else
#echo "127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4" > /etc/hosts
#echo "::1         localhost localhost.localdomain localhost6 localhost6.localdomain6" >> /etc/hosts
sed -i '/192.168.254/d' /etc/hosts
# add hostname to /etc/sysconfig/network
#echo "NETWORKING=yes" > /etc/sysconfig/network
#echo "HOSTNAME=$HOSTNAME" >> /etc/sysconfig/network
# build /etc/sysconfig/network-scripts/ifcfg-eth0
echo "DEVICE=eth0" > /etc/sysconfig/network-scripts/ifcfg-eth0
echo "ONBOOT=yes" >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo "BOOTPROTO=static" >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo "IPADDR=$IP" >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo "NETMASK=$NETMASK" >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo "GATEWAY=$GATEWAY" >> /etc/sysconfig/network-scripts/ifcfg-eth0
echo "ETHTOOL_OPTS=\"autoneg on\"" >> /etc/sysconfig/network-scripts/ifcfg-eth0
chmod 644 /etc/sysconfig/network-scripts/ifcfg-eth0
# remove persistent udev
rm -rf /etc/udev/rules.d/70-persistent-net.rules
fi
# remove DO-NOT-RUN.sh script used to wipe host
rm -rf /DO-NOT-RUN.sh
# reboot VM
# init 6
The following is the  windows cmd file.
This is copy to notepad and saved as c:\vix.cmd
echo "%1 %2 %3" > c:\vix.out
c:\\Windows\\System32\\netsh.exe interface set interface name="Local Area Connection" newname="%1"
c:\\Windows\\System32\\netsh.exe interface ip set address "%1" static %1 %2 %3
Examples:
staabrah
Community Member
I couldn't find vix.cmd and a.sh files
Orf Gelbrich
Where is the link?
