cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
15
Útil
Respostas
Match em dial peer
Olá a todos,
Tenho uma conexão ISDN E1 e os seguintes dial peers configurados no gateway:
dial-peer voice 1 pots
translation-profile incoming DID-STRIP
direct-inward-dial
port 0/0/0:15
dial-peer voice 201 voip
destination-pattern 9.......
session protocol sipv2
session target ipv4:10.0.0.127
session transport udp
voice-class codec 1
dtmf-relay rtp-nte
ip qos dscp cs3 signaling
no vad
No entanto, as chamadas vindas da PSTN através do link E1 falham:
Oct  9 14:43:38 UTC: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0DF4
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 15
        Facility i = 0x9F8B0100A10F02010B06072A8648CE1500040A0100
                Protocol Profile =  Networking Extensions
                0xA10F02010B06072A8648CE1500040A0100
                Component = Invoke component
                        Invoke Id = 11
                        Operation = InformationFollowing (calling_name)
                                Name information in subsequent FACILITY message
        Calling Party Number i = 0x2183, '1128038030'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '2129381100'
Oct  9 14:43:38 UTC: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8DF4 callID = 0x114A switch = primary-ni interface = User
Oct  9 14:43:38 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1128038030, Called Number=2129381100, Voice-Interface=0x49504F40,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
Oct  9 14:43:38 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
   Calling Number=1128038030, Called Number=2129381100, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
Oct  9 14:43:38 UTC: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8DF4
        Cause i = 0x809C - Invalid number format (incomplete number)
Alguma ideia do que pode estar causando a falha?
Agradeço desde já.
2 Soluções Aceitas
Soluções aceites
Andre Castro
Ola Christopher,
Parece que o a chamada entrante não encontra nenhum dial-peer como candidato para combinar com o número discado.
Se vc deseja que a chamada entre pela interface E1, no dial-peer 1 sugiro configurar um dos critérios utilizados pelo gateway para recebê-la, por exemplo:
dial-peer voice 1
  incoming called-number .
Do contrário, o dial-peer permanecerá desativado.
Aplique algum dos critérios como no exemplo e verifique se funciona.
Um abraço,
Ver solução na publicação original
Ola Christopher,
Em adição as dicas do André, de uma olhada neste documento para um melhor entendimento de como um dial-peer de entrada é selecionado.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Att
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
4 RESPOSTAS 4
Andre Castro
Ola Christopher,
dial-peer voice 1
Um abraço,
Ola Christopher,
Att
Leonardo Santana
Leonardo Santana
Muito obrigado pessoal pelos esclarecimentos.
No entanto ainda fica confuso para mim, pois o documento também afirma:
Voice-port (associated with the incoming call setup request) with configured dial peer port (applicable for inbound POTS call legs)
If no match is found in the step 3, the router or gateway attempts to match the configured dial peer port to the voice-port associated with the incoming call. If multiple dial peers have the same port configured, the dial peer first added in the configuration is matched.
O que me levaria a acreditar que o match seria dado mesmo na porta configurada (port 0/0/0:15) neste caso de dial peer pots.
De toda maneira obrigado, funcionou com as dicas dadas.
Abraços
Tem certa razão Christopher.
Complementando o documento que o Leonardo forneceu (+5), segue:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml#topic11
Destination-pattern is configured and a voice-port or session target is also configured.
Você pode até verificar o estado de operação do dial peer antes e depois de configurar algum dos 3 critérios indicados no documento, com o comando 'show dial-peer voice summary'.
Um abraço
