cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Monitorar canais E1s
lucas.leandro11
Caros, surgiu uma demanda em meu ambiente e gostaria de obter algumas sugestões. Preciso de uma ferramenta que monitore os canais dos meus E1s (R2 - Instalados em um router 3945  ) e que eu consiga extrair relatório históricos de utilização. Sugestões?
Desde já obrigado.
1 RESPOSTA 1
Leonardo Santana
Olá Lucas,
Verifique o Cisco Prime Collaboration:
https://supportforums.cisco.com/t5/collaboration-voice-and-video/monitoring-current-call-volume-on-gateway-using-cisco-prime/ta-p/3134094
Cisco Prime Collaboration performs trending of the following categories on a Cisco UBE:
• Resource usage (DSP and its channels)
• Call statistics (active calls)
• Trunk statistics (trunk usage at DS0 level, port usage, gateway statistics)
• MTP and Transcoder Sessions usage
• Total, Inbound, Outbound Call Volume both at interface and dial-peer level
You can view the performance report or graphs over the past 7 days by selecting the Performance right-click option on the device from the UC Topology View, and then selecting the performance parameter that you want to view. You can view multiple performance reports or graphs in a single screen
Verifique o RTMT tambem para realizar esta tarefa, caso esteja utilizando o CUCM como call controll:
https://supportforums.cisco.com/t5/unified-communications/channels-of-e1-t1-being-monitored-thru-rtmt/td-p/2835961
Veja a possibilidade de criar alertas customizados para as E1, caso seja possivel:
https://www.netcraftsmen.com/creating-custom-alerts-in-rtmt/
Att
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
