The dial-peer is not routing the call, using the voip network. When the call goes, I got an unassigned number error:
Successful Calls = 0, Failed Calls = 8, Incomplete Calls = 0
Last Disconnect Text is "unassigned number (1)",
The Call Flow is: (0111) E1 > ISR A > IP network > ISR B > E1(9111)
ISR A
voice-port 0/0/0:14
auto-cut-through
define Tx-bits idle 1101
define Tx-bits seize 0101
define Rx-bits idle 1101
define Rx-bits seize 0101
no ignore rx-b-bit
no ignore rx-c-bit
no ignore rx-d-bit
connection plar tied 9111
dial-peer voice 911 voip
destination-pattern 911.
session target ipv4:172.100.20.2
codec g711alaw
dial-peer voice 111 pots
destination-pattern 0111
port 0/0/0:14
ISR B
voice-port 0/1/0:6
auto-cut-through
no ignore rx-b-bit
no ignore rx-c-bit
no ignore rx-d-bit
connection plar tied 0111
dial-peer voice 119 voip
destination-pattern 011.
session target ipv4:172.100.20.5
codec g711alaw
dial-peer voice 9111 pots
destination-pattern 9111
port 0/1/0:6
I attached the dial plan test in TXT file
