Android L2TP/IPSec problem
dennylester
Level 5
Level 5
I have an ASA5505 configured to accept L2TP/IPSec VPN connections. I validated the setup by connecting via Windows 7 box and can ping across the tunnel. Using a Sprint HTC Evo Android version 2.2 I can also get connected to the VPN, however, when I try to ping across the link, the debug on the ASA is showing the Android is using it's WiFi IP address instead of the address assigned to the tunnel.
At this point I'm not sure if this is an Android problem or if I missed something in the ASA config.
Any suggestions?
Denny
0 Replies 0
