Anyconnect users need to use FQDN after connecting
toxicman
We are experincing a problem with only some of our home based users. they VPN in just fine and can reach any servers by using the FQDN such as internalhost.company.com, however they cannot resolve "internalhost".  The issue seems to be somewhere between AD and Anyconnect potentially.  Our Group Policy is giving them DNS servers & the "company.com" domain but it doesn't seem to be properly injecting.
A wireshark capture shows this when the user tries to ping internalhost:
Client -> ASA specified DNS server -> Query internalhost.ad.domain.com
ASA specified DNS server -> Client -> No Such Name
Client -> Home subnet DNS server -> Query internalhost.ad.domain.com
Home subnet DNS server -> Client -> Response w/ Home ISP homepage IP
I'm not sure why 2 things are happening here:
1) While the client is a member of the AD, they should be using company.com first, I thought AnyConnect put the Group Policy domain at the top of the list
2) Why is the client reaching out to the Home subnet DNS server second? We are providing 2 DNS servers via AnyConnect, and that subnet isn't even part of the Split Tunnel group. AnyConnect seems to be bypassing the Split Tunnel rules we have specified.
Any ideas or suggestions? We are on the latest windows version 2.5.3055 and running windows 7.
Thanks!
~Jason
12 Replies 12
Hi Jason,
Please do the following:
group-policy specific_group_policy attributes
     split-dns value ad.domain.com
split-dns
Let me know how it goes.
Thanks.
Portu.
Please rate any helpful posts.
Thanks Portu,
I checked our config & I see this in our DfltGrpPolicy, but not under the one our users connect in via.  Those only have the
"default-domain value company.com"
I suspect for our case we'd add "
"split-dns value company.com"
as that's where about 95% of our DNS entries exist.  Typically the computers will eventually try that value, but I suspect it's not proceeding through the suffix list as the Home ISP DNS service is providing an IP.
I'll post back after we try this out.
~Jason
Thanks for the quick response.
I would suggest this instead:
     split-dns value  company.com ad.domain.com
You can add more if needed.
Keep me posted.
I was looking around & noticed that myself too. We have 5 or 6 internal AD domain names so I'll add them all during our test.  We are set to inherit from the Default policy, but that policy only has the root DNS name in the list. If this works, I'll update the default instead of all the individual policies.
Hoping to test with the user tomorrow.
Great!
Hope to hear good news from you tomorrow
Found a different user and tried this out with no luck. I added in all the domains to the split-dns list and it's still failing. This user doesn't have wireshark running, but we were seeing the same IP come back from a ping test.
One of the domains in the users suffix list is our standard domain, but it's the 6th one out of 7 listed.
This used to work for us on the old VPN Client software, but the ASA seems to have so many other features, I'm not finding the right one for this.
Here's a snip of our config. I tried adding the split-dns list to the Default too, with no luck, and also removing the domain name from the user Policy & let it inherit too, with no luck:
group-policy DfltGrpPolicy attributes
wins-server value 192.168.197.36 192.168.197.30
dns-server value 192.168.197.30 192.168.197.36
vpn-session-timeout 2880
vpn-tunnel-protocol ssl-client ssl-clientless
group-lock value DefaultWEBVPNGroup
ipsec-udp enable
ipsec-udp-port 22847
split-tunnel-policy tunnelspecified
split-tunnel-network-list value HomeSubnets
split-dns value americas.ad.company.com emea-aspac.ad.company.com dmz.ad.company.com asp.ad.company.com ad.company.com company.com oldcompanyname.com
smartcard-removal-disconnect disable
webvpn
  anyconnect mtu 1200
  anyconnect profiles value CompanyVPNProfile type user
  anyconnect ask none default anyconnect
  anyconnect ssl df-bit-ignore enable
!Here's the user profile
group-policy CompanyVPN internal
group-policy CompanyVPN attributes
ip-comp disable
group-lock value CompanyVPN
split-tunnel-policy excludespecified
address-pools value UserVPNPool
webvpn
  anyconnect ssl compression none
  always-on-vpn profile-setting
!HomeSubnets ACL, the user who tested today has a home subnet of 192.168.1.x, the user w/ wireshark is 192.168.11.x
access-list HomeSubnets standard permit 192.168.0.0 255.255.255.0
access-list HomeSubnets standard permit 192.168.1.0 255.255.255.0
access-list HomeSubnets standard permit 10.0.0.0 255.255.255.0
access-list HomeSubnets standard permit 192.168.8.0 255.255.255.0
access-list HomeSubnets remark another home subnet
access-list HomeSubnets standard permit 192.168.2.0 255.255.255.0
Hi Jason,
Checking your configuration I found:
Please make the following changes:
access-list HomeSubnets standard permit host 192.168.197.30
access-list HomeSubnets standard permit host 192.168.197.36
You will also need to add these two hosts to the NAT exempt rule.
In summary:
The DNS servers are not included in the SPLIT ACL. Please add them and adjust the NAT rules.
Thanks.
Portu.
Well that HomeSubnets is used for those who wish to enable local LAN access when they VPN in, if not we are going to tunnel all of their traffic.  hosts 192.168.197.30 & 192.168.197.36 exist on the ASA / corporate side of the VPN so we don't want them to be excluded from tunneling.  I was able to get a wireshark capture yesterday but the forum site here was down when I went to post.
Here we can see the user is trying to do a lookup when they just ping  "othersites" which has an internal DNS entry provided by 192.168.197.30  or .36 with the IP 192.168.10.247.
This wireshark shows the computer stepping through 2  Domain Suffixes against the VPN provided DNS servers, then trying 3  suffixes against their home subnet DNS server, then it goes back, does 3  more against the VPN provided, 1 more on the home subnet, then finally  makes it down the list to the one which properly resolves from the VPN  provided DNS server.
My temporary fix was to have the  user change their Cable Modem / Router to use non-ISP provided DNS  servers. it seems their home ISP basically returns any query so the user  could be redirected to their search page. (Cox is the provider in  question).
We would like to get this resolved though to  help with the numerous other users including those who may not have  control of their upstream DNS servers such as someone at a hotel.
I  can provide more config if that helps too, but looking at this  wireshark capture, it seems the computer is misbehaving by trying the  home ISP DNS server before exhausting the options provided by the ASA /  Anyconnect.
Thoughts?
Jason,
Have you tried an "ipconfig /flushdns" while connected?
Thanks.
yep, we were trying that too, before every ping attempt, and we were disconnecting / reconnecting AnyConnect when making changes. I'll probably open a TAC case on this as it's been affecting a number of users and it's starting to become an issue for some with legacy applications that have the shortnames configured within them instead of the FQDN.
Hi Jason,
Have you tried with tunneall?
Indeed a TAC case is a good option, open one and ask for my assistance, I will be glad to help you further.
Thanks.
Portu
