AS5300 Memory Problem
nstahlman
Community Member
I just installed new memory in my old AS5300. Now I am getting the following error message. I know this is a stupid question, but could anything ELSE be causing this error instead of the memory? The only reason I ask is because I am able to RX-BOOT and TFTP up an IOS. The problem only occurs when booting the IOS. Could there been a compatibility issue with the new DRAM and the existing Packet Memory?
System Bootstrap, Version 11.2(9)XA, RELEASE SOFTWARE (fc2)
Copyright (c) 1997 by cisco Systems, Inc.
AS5300 platform with 131072 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0xf5914
Self decompressing the image : ################################################### [OK]
%SYS-4-CONFIG_NEWER: Configurations from version 12.0 may not be correctly understood.
Error: primary data cache, fields: data, SysAD
virtual addr 0x60628200, physical addr(21:3) 0x228200, vAddr(14:12) 0x0000
*** System received a Cache Parity Exception ***
signal= 0x14, code= 0xa4228200, context= 0x602631b0
PC = 0x600c1664, Cause = 0x20, Status Reg = 0x34008002
wong34539
Level 11
Level 11
Cache parity error exceptions occur when bad parity has been discovered in the CPU or in the primary data cache. The parity error could have occurred in the VIP DRAM, the DRAM controller, the primary cache, or in the CPU itself. Parity errors discovered in this location are also referred to as processor memory parity errors (PMPEs).
Check the following link for more information on this error :
http://www.cisco.com/en/US/products/hw/modules/ps2643/products_tech_note09186a0080094b15.shtml#parityerrors
