CAN NOT SETUP TWO FLEX TUNNELS TO THE SAME HUB FROM THE SAME SPOKE
oscarsd33
Im trying to setup a FlexVPN in a HA schema, so i am trying to get up two tunnels from my spoke router to the VPN HUB 1, but just one of the tunnels stay up.
can anyone help me
thanks..
Michael Muenz
Level 5
Level 5
Tunnel destinatin IP for HUB1 is identical?
Michael Please rate all helpful posts
Hi Michael, yes, on spoke, tunnel interfaces are pointing to the same IP at HUB1
And how do you influence the routing? If you have only a default route the traffic is only going via line1.
Normally you only achive this with tracking so only one connection is up while the other is standby
will user pbr to influence routing and also tracking feature, but the problem is that can not keep up two tunnles pointing the same HUB, if i shutdown one tunnel then other one come up.. and i need them to stay up both at the same time ..
