01-23-2003 10:13 AM - edited 02-21-2020 12:18 PM
Hi, in Cisco Bugtool, there are some bugs related with module AIM/VPN-EP module.
We have a 3640 router, and I has been some problems.
The vpn works in the most of time, but, in a few moments, the communication stops, and a communication fails, and suddenly the connection works.
The related bug that I found is CSCdz61466, and there are others bugs related with this, that say to disable hardware encryption.
I would like to know, which way to disable this module.
There are some command for this , or only way is desinstaling the moduling.?
Anyone have a idea about this?
the tunnel vpn is closed by a router 3640 and a 1720 with ios c3640-jk9s-mz.122-8.T5.bin in both sides.
I verified many times the configuration of routers and make a troubleshooting with them, and i have sure every is allright.
thanks...
01-29-2003 08:06 AM
I think you can shutdown all the interfaces on the AIM/VPN-EP module to disable it. Ofcourse, deinstalling it physically is also one of the ways of disabling it.
02-03-2003 10:14 AM
I believe this does it:
no crypto engine accelerator
