Help setting up SSL VPN
fishingredneck6
Community Member
Okay guys so I am having some issues!
ASA 8.2
ASDM 7.1
I have created a SSL VPN using the wizard I selected both clientless and anyconnect. I am able to get to my portal page and login but am not able to get to anything using the cifs:// ..... Oddly enough tho I am able to access a couple of our local intranet pages which I made a bookmark for. Also I am not able to get any response at all on the anyconenct client
I can provide any more information needed just let me know!
My guess it has something to do with the nat settings and me needing to allow some port but honestly I know nothing about adding stuff to nat I just started and this is my first big task!
Jeet Kumar
Please attach the configuration.
Result of the command: "show running-conf"
: Saved
ASA Version 8.2(5)
hostname ciscoasa
domain-name bbdsllc.local
enable password 2KFQnbNIdI.2KYOU encrypted
passwd Omz7GuN4pi8hdHeW encrypted
names
name 192.168.2.15 BBDSDC
name 192.168.2.16 BBDSLLCCRM
name 108.253.99.26 anotheroutsideip
name 108.253.99.25 outside_ip
name 71.14.4.34 charter_ip
name 192.168.2.118 BBDS_Demo
interface Ethernet0/0
description Outside Interface
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
ospf cost 10
interface Vlan2
nameif outside
security-level 0
ip address outside_ip 255.255.255.248
ospf cost 10
interface Vlan3
nameif charter
security-level 0
ip address charter_ip 255.255.255.252
banner login test
boot system disk0:/asa825-k8.bin
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns domain-lookup charter
dns server-group DefaultDNS
name-server BBDSDC
object-group network POSTINI
network-object 64.18.0.0 255.255.240.0
object-group service CRM tcp
port-object eq 5555
object-group service CRMHTTPS tcp
description HTTPS Port for CRM
port-object eq 5000
object-group service 8083_Action_Tire tcp
port-object eq 8083
object-group service BBDSLLCCRM tcp
port-object eq 7000
object-group service EWS tcp
port-object eq 2070
object-group service iMAPISecure tcp
port-object eq 993
object-group service ewriter tcp
port-object eq 6969
object-group service FORMOTUS-WebService tcp
port-object eq 6970
object-group service BBDSDEMO_InternetWebPage tcp
port-object eq 7070
object-group network McAfee_Spam_Group
network-object 208.65.144.0 255.255.240.0
object-group network McAfee_Spam_Group2
network-object 208.81.64.0 255.255.240.0
object-group network MSOFT-FPOE
network-object 12.129.20.0 255.255.255.0
network-object host 12.129.199.61
network-object host 12.129.219.155
network-object 63.241.222.0 255.255.255.0
network-object 65.55.88.0 255.255.255.0
network-object 94.245.120.0 255.255.255.0
network-object host 206.16.57.70
network-object 207.46.51.0 255.255.255.0
network-object 207.46.163.0 255.255.255.0
network-object 213.199.154.0 255.255.255.0
network-object 213.199.180.0 255.255.255.0
network-object 216.32.180.0 255.255.255.0
network-object 216.32.181.0 255.255.255.0
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list nonat extended permit ip 10.150.1.0 255.255.255.0 10.50.2.0 255.255.255.0
access-list inside_access_in extended permit icmp any any
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp any any eq ssh
access-list inside_access_in extended permit tcp any any object-group EWS
access-list inside_access_in extended permit udp any any eq isakmp
access-list outside_access_in extended permit tcp any host outside_ip eq 7070
access-list outside_access_in extended permit tcp any interface outside eq www
access-list outside_access_in extended permit tcp any interface outside eq 3389
access-list outside_access_in extended permit tcp any interface outside eq ftp
access-list outside_access_in extended permit tcp any interface outside eq 444
access-list outside_access_in extended permit tcp any interface outside eq https
access-list outside_access_in extended permit tcp 208.65.144.0 255.255.255.248 interface outside eq smtp
access-list outside_access_in extended permit tcp any interface outside object-group BBDSLLCCRM
access-list outside_access_in extended permit tcp any interface outside object-group CRMHTTPS
access-list outside_access_in extended permit tcp any interface outside object-group 8083_Action_Tire
access-list outside_access_in extended permit tcp any any eq ssh
access-list outside_access_in extended permit tcp any any object-group EWS
access-list outside_access_in extended permit tcp any interface outside object-group iMAPISecure
access-list outside_access_in extended permit udp any any eq isakmp
access-list outside_access_in extended permit tcp host 76.184.218.121 interface outside eq smtp inactive
access-list outside_access_in extended permit tcp any host outside_ip object-group ewriter
access-list outside_access_in extended permit tcp 208.81.64.0 255.255.255.252 interface outside eq smtp
access-list outside_access_in extended permit tcp object-group McAfee_Spam_Group interface outside eq smtp
access-list outside_access_in extended permit tcp object-group McAfee_Spam_Group2 interface outside eq smtp
access-list outside_access_in extended permit tcp object-group MSOFT-FPOE interface outside eq smtp
access-list BBDS-RA-IPSEC_splitTunnelAcl standard permit 192.168.2.0 255.255.255.0
access-list charter_access_in extended permit tcp any interface charter eq www
access-list charter_access_in extended permit tcp any interface charter eq 3389
access-list charter_access_in extended permit tcp any interface charter eq ftp
access-list charter_access_in extended permit tcp any interface charter eq 444
access-list charter_access_in extended permit tcp any interface charter eq https
access-list charter_access_in extended permit tcp 208.81.64.0 255.255.255.252 interface charter eq smtp
access-list charter_access_in extended permit tcp any interface charter object-group BBDSLLCCRM
access-list charter_access_in extended permit tcp any interface charter object-group CRMHTTPS
access-list charter_access_in extended permit tcp any interface charter object-group 8083_Action_Tire
access-list charter_access_in extended permit tcp any any eq ssh
access-list charter_access_in extended permit tcp any any object-group EWS
access-list charter_access_in extended permit tcp any interface charter object-group iMAPISecure
access-list charter_access_in extended permit udp any any eq isakmp
access-list charter_access_in extended permit tcp host 76.184.218.121 interface charter eq smtp inactive
access-list charter_access_in extended permit tcp any host charter_ip object-group ewriter
access-list charter_access_in extended permit tcp any host charter_ip object-group FORMOTUS-WebService
access-list charter_access_in extended permit tcp any host BBDS_Demo object-group BBDSDEMO_InternetWebPage
access-list charter_access_in extended permit tcp 208.65.144.0 255.255.255.248 interface charter eq smtp
access-list charter_access_in extended permit tcp object-group McAfee_Spam_Group interface charter eq smtp
access-list charter_access_in extended permit tcp object-group McAfee_Spam_Group2 interface charter eq smtp
access-list charter_access_in extended permit tcp object-group MSOFT-FPOE interface charter eq smtp
access-list NONAT extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list LIVEIT-VDC extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list SplitTUnnel standard permit 192.168.2.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu charter 1500
ip local pool BBDSOFF 192.168.4.1-192.168.4.250 mask 255.255.255.0
ip local pool BBDSVPNPOOL 10.10.10.1-10.10.10.30 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any charter
asdm image disk0:/asdm-714.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (charter) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface https BBDSDC https netmask 255.255.255.255
static (inside,outside) tcp interface www BBDSDC www netmask 255.255.255.255
static (inside,outside) tcp interface smtp BBDSDC smtp netmask 255.255.255.255
static (inside,outside) tcp interface ftp 192.168.2.80 ftp netmask 255.255.255.255
static (inside,outside) tcp interface 444 192.168.2.80 444 netmask 255.255.255.255
static (inside,outside) tcp interface 3389 192.168.2.80 3389 netmask 255.255.255.255
static (inside,outside) tcp interface 5000 BBDSLLCCRM 5000 netmask 255.255.255.255
static (inside,outside) tcp interface 8083 192.168.2.80 8083 netmask 255.255.255.255
static (inside,outside) tcp interface 7000 BBDSDC 7000 netmask 255.255.255.255
static (inside,outside) tcp interface 993 BBDSDC 993 netmask 255.255.255.255
static (inside,outside) tcp interface 6969 192.168.2.150 6969 netmask 255.255.255.255
static (inside,outside) tcp interface 6970 192.168.2.150 6970 netmask 255.255.255.255
static (inside,charter) tcp interface https BBDSDC https netmask 255.255.255.255
static (inside,charter) tcp interface www BBDSDC www netmask 255.255.255.255
static (inside,charter) tcp interface smtp BBDSDC smtp netmask 255.255.255.255
static (inside,charter) tcp interface ftp 192.168.2.80 ftp netmask 255.255.255.255
static (inside,charter) tcp interface 444 192.168.2.80 444 netmask 255.255.255.255
static (inside,charter) tcp interface 3389 192.168.2.80 3389 netmask 255.255.255.255
static (inside,charter) tcp interface 5000 BBDSLLCCRM 5000 netmask 255.255.255.255
static (inside,charter) tcp interface 8083 192.168.2.80 8083 netmask 255.255.255.255
static (inside,charter) tcp interface 7000 BBDSDC 7000 netmask 255.255.255.255
static (inside,charter) tcp interface 993 BBDSDC 993 netmask 255.255.255.255
static (inside,charter) tcp interface 6969 192.168.2.150 6969 netmask 255.255.255.255
static (inside,charter) tcp interface 6970 192.168.2.150 6970 netmask 255.255.255.255
static (inside,charter) tcp interface 7070 BBDS_Demo 7070 netmask 255.255.255.255
static (inside,outside) tcp interface 7070 BBDS_Demo 7070 netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
access-group charter_access_in in interface charter
route charter 0.0.0.0 0.0.0.0 71.14.4.33 1 track 100
route outside 0.0.0.0 0.0.0.0 108.253.99.30 240
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server LDAPNT protocol ldap
aaa-server LDAPNT (inside) host BBDSDC
server-port 389
ldap-base-dn dc=bbdsllc, dc=local
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-password *****
ldap-login-dn CN=ASA VPN, OU=VPN, DC=BBDSLLC, DC=local
server-type microsoft
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 inside
http 76.185.223.186 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sla monitor 1
type echo protocol ipIcmpEcho 4.2.2.2 interface charter
sla monitor schedule 1 life forever start-time now
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map dynmap 65535 set transform-set ESP-AES-256-MD5
crypto dynamic-map dynmap 65535 set reverse-route
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto map charter_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map OUTSIDE_MAP 10 match address LIVEIT-VDC
crypto map OUTSIDE_MAP 10 set peer 209.105.254.187
crypto map OUTSIDE_MAP 10 set transform-set ESP-AES-256-SHA
crypto map OUTSIDE_MAP interface outside
crypto map OUTSIDE_MAP interface charter
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
fqdn ciscoasa
subject-name CN=ciscoasa
proxy-ldc-issuer
crl configure
crypto ca trustpoint ASDM_TrustPoint1
fqdn ciscoasa
crl configure
crypto ca trustpoint ASDM_TrustPoint2
fqdn ciscoasa
crl configure
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca server
shutdown
crypto ca certificate chain ASDM_TrustPoint0
certificate 31
    30820231 3082019a a0030201 02020131 300d0609 2a864886 f70d0101 04050030
    2c311130 0f060355 04031308 63697363 6f617361 31173015 06092a86 4886f70d
    01090216 08636973 636f6173 61301e17 0d303830 37313331 35353834 345a170d
    31383037 31313135 35383434 5a302c31 11300f06 03550403 13086369 73636f61
    73613117 30150609 2a864886 f70d0109 02160863 6973636f 61736130 819f300d
    06092a86 4886f70d 01010105 0003818d 00308189 02818100 d5d4b06d 99aefcdf
    ec7f1fda ba6883a4 e2d88a52 0016ecc0 d4e29477 05fe74d3 34b3cd32 1333ad29
    a3975101 56ac9467 8b0d7cac 1dc2c25b c4d95c98 44f3b312 b41df82d 8726b87e
    9774b8d8 a7afc20c 94e20b8e 49892760 83d1d52a eebf180f 070b2b5d 7e17cb15
    897ebf5b a8de0097 defc5480 945427cf 2f2ea16e ca9032d1 02030100 01a36330
    61300f06 03551d13 0101ff04 05300301 01ff300e 0603551d 0f0101ff 04040302
    0186301f 0603551d 23041830 1680143f 1f572707 6c9da6a1 8189cee5 26f25383
    ed49e530 1d060355 1d0e0416 04143f1f 5727076c 9da6a181 89cee526 f25383ed
    49e5300d 06092a86 4886f70d 01010405 00038181 00849b24 9b7f4d5b 605d18cb
    0d9fab1b 91686efa 14d3f337 d11bc679 fc36fa22 5483417c 8ee09e84 cf98c93c
    8cb75dc2 192730ae 583ac866 ce131272 0b6c5d03 fef5a9b5 86550398 89aaa8e1
    44004138 82798b04 93dea4f2 95ccac8f 38ed987d f8dfdeea e76f4486 265d92f8
    4ba70064 d8f139c1 48c73f84 ef6ffa80 d33e38a8 47
  quit
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
    308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
    0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
    30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
    30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
    496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
    74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
    68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
    3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
    63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
    0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
    a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
    9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
    7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
    15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
    63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
    18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
    4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
    81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
    db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
    7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
    ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
    45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
    2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
    1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
    03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
    69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
    02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
    6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
    c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
    69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
    1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
    551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
    1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
    2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
    4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
    b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
    6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
    481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
    b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
    5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
    6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
    6c2527b9 deb78458 c61f381e a4c4cb66
  quit
crypto isakmp enable outside
crypto isakmp enable charter
crypto isakmp policy 10
authentication pre-share
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp policy 15
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
track 100 rtr 1 reachability
telnet 192.168.2.0 255.255.255.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh 192.168.2.0 255.255.255.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 charter
ssh timeout 60
ssh version 2
console timeout 0
dhcpd auto_config outside
dhcpd update dns both override
dhcpd address 192.168.2.100-192.168.2.131 inside
dhcpd dns BBDSDC 68.94.156.1 interface inside
dhcpd lease 604800 interface inside
dhcpd domain bbdsllc.local interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_TrustPoint0 charter
webvpn
port 42042
enable inside
enable outside
enable charter
svc image disk0:/anyconnect-win-2.2.0133-k9.pkg 1
svc enable
tunnel-group-list enable
group-policy BBDSOFF internal
group-policy BBDSOFF attributes
dns-server value 192.168.2.15
split-tunnel-policy tunnelspecified
split-tunnel-network-list value SplitTUnnel
default-domain value bbds.local
address-pools value BBDSOFF
group-policy BBDSSSL internal
group-policy BBDSSSL attributes
vpn-tunnel-protocol svc webvpn
webvpn
  url-list value CRM
  svc ask enable
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
webvpn
  svc ask enable
username gdowns password EFam5N83rM0la2pD encrypted privilege 15
username sdowns password ERtvNsuNKCmAYLCJ encrypted privilege 15
username zchandler password /Nql/DR2cCimcmoU encrypted privilege 15
username zchandler attributes
vpn-group-policy BBDSSSL
tunnel-group 209.105.254.187 type ipsec-l2l
tunnel-group 209.105.254.187 ipsec-attributes
pre-shared-key *****
tunnel-group BBDSVPN type remote-access
tunnel-group BBDSVPN general-attributes
address-pool BBDSVPNPOOL
default-group-policy BBDSSSL
tunnel-group BBDSOFF type remote-access
tunnel-group BBDSOFF general-attributes
address-pool BBDSOFF
authentication-server-group LDAPNT
tunnel-group BBDSOFF ipsec-attributes
tunnel-group-map default-group BBDSSSL
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:c7dcb1fab219291f29bb62d51bd2d770
: end
fishingredneck6
Community Member
still unable to get this to work properly! Looking for advice!
