High CPU Utilization on Cisco ASA 5520 - Dispatch Unit Process
shafhuss
Hi Team,
I am observing high cpu utlization on cisco asa 5520. I have found that Dispatch Unit process is causing high cpu. I have captured some of the outputs for following commands for your reference. Also, when i look into it, there are lots of LDAP queries and DNS Drops.
I see lots of input errors and overruns on Inside and Outside interface of the firewall as well. Can someone suggest what is causing this.
Process:      hostscan_token_cleaner, PROC_PC_TOTAL: 39, MAXHOG: 5, LASTHOG: 2
LASTHOG At:   05:46:28 UTC Mar 19 2018
PC:           0x096b4c0c (suspend)
Process:      hostscan_token_cleaner, NUMHOG: 30, MAXHOG: 5, LASTHOG: 2
Call stack:   0x096b4c0c  0x0806a65c
Process:      snmp, PROC_PC_TOTAL: 1, MAXHOG: 9, LASTHOG: 9
LASTHOG At:   08:44:46 UTC Mar 19 2018
PC:           0x091b4cd9 (suspend)
Process:      snmp, NUMHOG: 1, MAXHOG: 9, LASTHOG: 9
Call stack:   0x091b4cd9  0x09066edf  0x09041bc5  0x0903fb94  0x0806a65c
Process:      Unicorn Admin Handler, NUMHOG: 3, MAXHOG: 10, LASTHOG: 4
LASTHOG At:   10:17:31 UTC Apr 11 2018
PC:           0x0806d64e (suspend)
Call stack:   0x0806d64e  0x084e361d  0x084e1bf1  0x08cb1a33  0x0857a368  0x08572469  0x085726f2
              0x08572a2e  0x0857910b  0x0806a65c
Process:      Unicorn Proxy Thread, PROC_PC_TOTAL: 87, MAXHOG: 6, LASTHOG: 6
LASTHOG At:   10:18:14 UTC Apr 11 2018
PC:           0x091bdc05 (suspend)
Process:      Unicorn Proxy Thread, NUMHOG: 87, MAXHOG: 6, LASTHOG: 6
Call stack:   0x0806d5e0  0x091bdc05  0x091be11d  0x091d248d  0x091d3dec  0x092eed2b  0x092ed446
              0x092e8fdb  0x092e869a  0x092e9d15  0x092d9fda  0x092d966b  0x092d973c  0x092d2325
Process:      ssh, PROC_PC_TOTAL: 26, MAXHOG: 9, LASTHOG: 6
LASTHOG At:   10:19:47 UTC Apr 11 2018
PC:           0x08c887fd (suspend)
Process:      ssh, NUMHOG: 26, MAXHOG: 9, LASTHOG: 6
Call stack:   0x08c887fd  0x098e589e  0x08ea3e44  0x08c91e64  0x08c93901  0x080f7f0b  0x080fa046
              0x080faf7c  0x0806a65c
Process:      Dispatch Unit, PROC_PC_TOTAL: 773, MAXHOG: 5, LASTHOG: 2
LASTHOG At:   14:54:57 UTC Apr 12 2018
PC:           0x082a4169 (suspend)
Process:      Dispatch Unit, NUMHOG: 773, MAXHOG: 5, LASTHOG: 2
Call stack:   0x082a4169  0x0806a65c
Process:      ssh_init, NUMHOG: 178, MAXHOG: 3, LASTHOG: 2
LASTHOG At:   20:27:18 UTC Apr 12 2018
PC:           0x0911079d (suspend)
Call stack:   0x0911079d  0x09122720  0x09128c99  0x091162b4  0x0806a65c
Process:      snmp, PROC_PC_TOTAL: 51, MAXHOG: 11, LASTHOG: 11
LASTHOG At:   21:06:02 UTC Apr 12 2018
PC:           0x0906e5de (suspend)
Process:      snmp, NUMHOG: 51, MAXHOG: 11, LASTHOG: 11
Call stack:   0x0906e5de  0x0906d5b0  0x0906a50e  0x0906d146  0x09041d9b  0x0903fb94  0x0806a65c
Process:      emweb/https, NUMHOG: 4, MAXHOG: 5, LASTHOG: 2
LASTHOG At:   06:23:53 UTC Apr 13 2018
Call stack:   0x0806d64e  0x0832901f  0x0806a65c
Process:      emweb/https, NUMHOG: 186, MAXHOG: 7, LASTHOG: 7
LASTHOG At:   07:39:20 UTC Apr 13 2018
Call stack:   0x0806d64e  0x08328c1d  0x0806a65c
Process:      Session Manager, PROC_PC_TOTAL: 254, MAXHOG: 15, LASTHOG: 3
LASTHOG At:   09:50:18 UTC Apr 13 2018
PC:           0x08ff142d (suspend)
Process:      Session Manager, NUMHOG: 254, MAXHOG: 15, LASTHOG: 3
Call stack:   0x08ff142d  0x0806a65c
Process:      ssh, PROC_PC_TOTAL: 522, MAXHOG: 49, LASTHOG: 9
LASTHOG At:   09:55:35 UTC Apr 13 2018
Process:      ssh_init, NUMHOG: 283, MAXHOG: 10, LASTHOG: 9
Call stack:   0x0806d64e  0x081996cb  0x0984a75b  0x0984e7fa  0x09840a9e  0x09840cc7  0x0986579f
              0x098747e7  0x0986928a  0x081921d0  0x0815a0f2  0x09125ebb  0x09121606  0x0912010e
Process:      Unicorn Proxy Thread, PROC_PC_TOTAL: 9989, MAXHOG: 128, LASTHOG: 3
LASTHOG At:   09:55:52 UTC Apr 13 2018
PC:           0x091bce35 (suspend)
Process:      Unicorn Proxy Thread, NUMHOG: 9986, MAXHOG: 128, LASTHOG: 3
Call stack:   0x0806d5e0  0x091bce35  0x091bfb0d  0x091bfbc5  0x750ec8a4
Process:      ldap_client_thread, PROC_PC_TOTAL: 1209860, MAXHOG: 431, LASTHOG: 3
LASTHOG At:   09:58:44 UTC Apr 13 2018
PC:           0x091dba7d (suspend)
Process:      ldap_client_thread, NUMHOG: 1198801, MAXHOG: 431, LASTHOG: 3
Call stack:   0x0806c9ba  0x091dba7d  0x091bd7aa  0x091bfb0d  0x091bfbc5  0x00000014  0x098d868c
              0x091bdbe7  0x091bec97  0x088c0605  0x0806a65c
Process:      ssh_init, PROC_PC_TOTAL: 189, MAXHOG: 15, LASTHOG: 12
LASTHOG At:   09:58:45 UTC Apr 13 2018
Process:      ssh, NUMHOG: 8, MAXHOG: 15, LASTHOG: 12
Call stack:   0x0911079d  0x09122720  0x09124d9e  0x0911552b  0x09115896  0x09115d89  0x09117120
              0x08c873fc  0x098e61f0  0x08106c0d  0x080f9ead  0x080faf7c  0x0806a65c
Process:      Dispatch Unit, PROC_PC_TOTAL: 1761293, MAXHOG: 679, LASTHOG: 4
LASTHOG At:   09:58:46 UTC Apr 13 2018
PC:           0x082a4208 (suspend)
Process:      Dispatch Unit, NUMHOG: 1541326, MAXHOG: 679, LASTHOG: 4
Call stack:   0x082a4208  0x0806a65c
Process:      Dispatch Unit, PROC_PC_TOTAL: 21167702, MAXHOG: 821, LASTHOG: 3
PC:           0x082a445c (suspend)
Process:      Dispatch Unit, NUMHOG: 4586109, MAXHOG: 821, LASTHOG: 3
Call stack:   0x082a445c  0x0806a65c
CPU hog threshold (msec):  2.844
Last cleared: None
shafhuss
Please see some more command outputs.
IND-HYD-GSD-VPN-FW-01/pri/act# show interface
Interface GigabitEthernet0/0 "Outside", is up, line protocol is up
Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
Full-Duplex(Full-duplex), 1000 Mbps(1000 Mbps)
Input flow control is unsupported, output flow control is off
Description: - interface connecting to VPN_OUT of Uppal Internet firewall
MAC address 001c.58d3.f8f6, MTU 1500
IP address 58.2.238.23, subnet mask 255.255.255.224
15795135326 packets input, 4094502776608 bytes, 0 no buffer
Received 495531 broadcasts, 0 runts, 0 giants
34239993 input errors, 0 CRC, 0 frame, 34239993 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops
24520208688 packets output, 10874305004401 bytes, 0 underruns
0 pause output, 0 resume output
0 output errors, 0 collisions, 2 interface resets
0 late collisions, 0 deferred
0 input reset drops, 0 output reset drops, 0 tx hangs
input queue (blocks free curr/low): hardware (255/230)
output queue (blocks free curr/low): hardware (255/97)
Traffic Statistics for "Outside":
15794944374 packets input, 3781578180407 bytes
24520208688 packets output, 10366793510014 bytes
138424540 packets dropped
1 minute input rate 5673 pkts/sec, 1299714 bytes/sec
1 minute output rate 8783 pkts/sec, 3732798 bytes/sec
1 minute drop rate, 58 pkts/sec
5 minute input rate 5998 pkts/sec, 1413782 bytes/sec
5 minute output rate 9200 pkts/sec, 3745219 bytes/sec
5 minute drop rate, 64 pkts/sec
Interface GigabitEthernet0/1 "Inside", is up, line protocol is up
Description: - interface connecting to VPN_IN of Uppal Internet firewall
MAC address 001c.58d3.f8f7, MTU 1500
IP address 58.2.64.43, subnet mask 255.255.255.224
13672161203 packets input, 9092690613902 bytes, 0 no buffer
Received 125930 broadcasts, 0 runts, 0 giants
68992986 input errors, 0 CRC, 0 frame, 68992986 overrun, 0 ignored, 0 abort
0 L2 decode drops
11138084894 packets output, 2794033178367 bytes, 0 underruns
output queue (blocks free curr/low): hardware (253/0)
Traffic Statistics for "Inside":
13672161173 packets input, 8832327224938 bytes
11138084894 packets output, 2557197084862 bytes
296806020 packets dropped
1 minute input rate 4948 pkts/sec, 3195541 bytes/sec
1 minute output rate 3942 pkts/sec, 831289 bytes/sec
1 minute drop rate, 107 pkts/sec
5 minute input rate 5157 pkts/sec, 3230104 bytes/sec
5 minute output rate 4222 pkts/sec, 945345 bytes/sec
5 minute drop rate, 160 pkts/sec
Interface GigabitEthernet0/2 "state_failover", is up, line protocol is up
Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
Description: LAN/STATE Failover Interface
MAC address 001c.58d3.f8f8, MTU 1500
IP address 192.168.16.1, subnet mask 255.255.255.0
7108037 packets input, 613847480 bytes, 0 no buffer
Received 302 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops
402282378 packets output, 494877025372 bytes, 0 underruns
0 output errors, 0 collisions, 15 interface resets
7 input reset drops, 0 output reset drops, 0 tx hangs
input queue (blocks free curr/low): hardware (255/232)
output queue (blocks free curr/low): hardware (255/176)
Traffic Statistics for "state_failover":
7107905 packets input, 457794966 bytes
402282244 packets output, 487635833616 bytes
0 packets dropped
1 minute input rate 1 pkts/sec, 84 bytes/sec
1 minute output rate 162 pkts/sec, 198240 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 1 pkts/sec, 96 bytes/sec
5 minute output rate 181 pkts/sec, 221471 bytes/sec
5 minute drop rate, 0 pkts/sec
Interface GigabitEthernet0/3 "TEST", is down, line protocol is down
Auto-Duplex, Auto-Speed
MAC address 001c.58d3.f8f9, MTU 1500
IP address 192.168.1.1, subnet mask 255.255.255.0
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 L2 decode drops
0 packets output, 0 bytes, 0 underruns
input queue (blocks free curr/low): hardware (255/255)
output queue (blocks free curr/low): hardware (255/255)
Traffic Statistics for "TEST":
1041509 packets dropped
1 minute input rate 0 pkts/sec, 0 bytes/sec
1 minute output rate 0 pkts/sec, 0 bytes/sec
5 minute input rate 0 pkts/sec, 0 bytes/sec
5 minute output rate 0 pkts/sec, 0 bytes/sec
Interface Management0/0 "", is administratively down, line protocol is down
Hardware is i82557, BW 100 Mbps, DLY 100 usec
Input flow control is unsupported, output flow control is unsupported
Available but not configured via nameif
MAC address 001c.58d3.f8fa, MTU not set
IP address unassigned
0 L2 decode drops
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max packets): hardware (0/0) software (0/0)
output queue (curr/max packets): hardware (1/0) software (0/0)
IND-HYD-GSD-VPN-FW-01/pri/act# show interface | include errors
34240055 input errors, 0 CRC, 0 frame, 34240055 overrun, 0 ignored, 0 abort
68993045 input errors, 0 CRC, 0 frame, 68993045 overrun, 0 ignored, 0 abort
Some more
Last
Hello All,
Any updates. Please help me with this.
Shaf
