07-10-2013 04:05 AM
Dear Experts,
We have 4 sites at remote locations with Broadband Internet connected to HQ via Easy VPN.
The communication between Easy VPN Remote to Easy VPN server is working ok.
Now the requirement is have communication between Easy VPN Remote to Easy VPN Remote.
Can anybody help how it will be possible?
07-10-2013 08:33 AM
Any experts,
if you know, please revert.
07-10-2013 08:49 AM
do you mean traffic tunnel to hub and goes to another site? it should work. check if you have RRI enabled or not
07-10-2013 09:04 AM
Not Get it.
Yes, It is ok if Traffic from one remote site to HUB site and to Other remote site.
Can you share the example?
07-10-2013 09:11 AM
something like this
crypto dynamic-map dynmap 1
set transform-set transform-1
reverse-route
07-10-2013 10:55 AM
Hi Li,
Pls. reply.
regards
07-11-2013 12:01 AM
Dear Experts,
Please reply.
07-12-2013 09:04 PM
Dear All,
Anybody can help in this matter?
