ipsec tunnel problem works without configuration on asa
lbellicaud
Hi everyone,
I have a problem with one asa version 8.4.3.
I have a tunnel that mount with a remote site if I did not configure the tunnel and if I configure it does not mount
someone you already see that? With version 8.2, we had no worries but since migration problem there.
With configuration tunnel we have this error:
IKEv1]: Group = x.x.x.x, IP = x.x.x.x, QM FSM error (P2 struct &0x49ba5a0, mess id 0xcd600011)!
[IKEv1]: Group = x.x.x.x, IP = x.x.x.x, Removing peer from correlator table failed, no match!
Thanks for your response
Marvin Rhoads
I've never seen that as the result of a simple ASA upgrade but in general there are a couple of things that could cause this issue. Generally it is an unidentified peer or peer without valid crypto map trying to establish a site-site VPN that results in the above message.
Please have a look at this troubleshooting guide.
If that doesn't help. please post your script
Marvin Rhoads
