Ipsec within ipsec problem
Jeppe Flensted
Frequent Visitor
Frequent Visitor
So this is the scenario:
- Ipsec tunnell between two 881's
- An Aruba access point trying to set up a tunnell back to controller through the ipsec tunnell, on udp 4500
- Even though traffic shouldn't be NAT'ed (and other traffic is not), udp 4500 is NAT'ed
I guess this might be default behaviour, thing is that it used to work when it was set up as a route based easy vpn.
Anyone got a good idea for a workaround?
andrew.prince
Level 11
Level 11
Create a GRE tunnel between the routers, that traverses the VPN. Then put the aruba traffic into the GRE tunnel.
