Multiple incoming calls using dialer profiles
br
Dear all,
I try to configure a 3640 (IOS: IP PLUS 12.3(16a)) to accept more than one call using dialer profiles. Here is my config:
http://rafb.net/paste/results/JNrw5m76.html
And here the log-output:
http://rafb.net/paste/results/dX9Usb22.html
When a 2nd call comes in the error message is :
Di0: Load balancing not supported, rejecting call
What do I wrong? Please help.
Best regards,
Bernhard Roth
a-larkins
I tried your links, but they say thet the file is not there.
Anyway - is this a RAS solution for users dialup or more likebackup interfaces from branches to a central site.
Here is my "sh ver" output and my config.
The RAS solution is for user-dialup to our site. The clients are using X.25 on the ISDN B-channel.
Thank you and best regards
Bernhard
what are the users using to dial up ISDN or analogue?
the users are connecting via analogue and ISDN. analog works fine as it goes directly to the digital modems.
ISDN X.25 is the only variant which does not work with more than one simultanous connection.
