Not able to connect with some android clients
CiscoDiginet
we use Cisco ASA and AnyConnect clients. Some Android systems work but those which use the Cisco AnyConnect ICS+ client got the following error
Connection attempt failed because system configuration settings could not be applied
Any Idea?
Thank you in advance
Ralf
LJ Gabrillo
Level 5
Level 5
What I usually do (well in the IOS router side) is lower down my MTU
max is 1406, but I use 1392
I also apply it in the virtual interface as well
Try using it
