Problem configuring a Cisco 837 router and XP vpn clients using PPTP & MPPE
dp_durham1
I wonder if anyone can help ?.
I am trying to configure VPN access to a Cisco 837 router from Windows XP.
I have followed all the documentation for this and it still doesn't work.
If I apply the same config to a 1721 it works fine.
Is what I am trying valid on 837 ?, any help would be much appreciated.
mhussein
Level 4
Level 4
What IOS version and feature set are you using? Could you also post the router configs (remember to mask/remove public ip address and sensitive info)
Mustafa
