Problems Installing VPN Client on Intel iMac Core Duo
nbrown911
We tried installing the VPN Client software (v.4.9.00.0050) on an Intel Core Duo iMac by dragging the application into the applications folder on the hard drive. When trying to start VPN Client, it gave a message referring to "architecture not supported) and wouldn't start up. We have installed this successfully on other macs outside our office without problems. Does anyone have any suggestions?
mchin345
Level 6
Level 6
For such appkcation to work in a platfrom you need to install the application using the stansard installer supplied with the application.
For more information refer the url given below,
http://www.cisco.com/en/US/products/sw/secursw/ps2308/prod_release_note09186a00806ecf3b.html
