Problems SDSL PPPOE
jbusch
Community Member
Hi to all,
i have a problem with a Cisco 1841 connecting to a SDSL Modem using PPPOE, everything works perfect but after 1 or 2 days the performance gets very poor
80% paket loss, shutting down the interfaces(dialer and Fast ethernet ) will have no effect, also clear interface, clear VPDN session clear pppoe session will have no effect,
after reboot everything works pretty fine
Can You please help me ??
Georg Pauwen
which IOS version are you using ? Could be a bug...
GP
thanks fpr Your answer, You are rught i was running IOS 12.3.11 after downgrading to 12.3.9.T5 everything seems to run smoothly
JB
