Problems with CSA & Cisco VPN combined
efink
Hello, everyone !
I have a particular problem: on all machines where CSA 4.0.3 716 and Cisco VPN client 4.6 are installed the only way I can connect to remote site is using VPN connection. Dial up in this case doesn't work. If you disable network shim or stop CSA service that is not a case anymore. I don't need to tell you I don't like both workarunds.
Anyone knows solution.
Thnks.
pcomeaux
Hey there -
I know CSA 4.0.3.720 was released soon after 4.0.3.716 to address some issues. I believe I saw some e-mails on Cisco mail lists regarding the same problem you are running into.
Please try this version and let us know if you still experience the problem:
http://www.cisco.com/cgi-bin/tablebuild.pl/csa
thanks
peter
Hello, Peter
My problem has been resolved with applying 4.0.3 723 version of CSA.
Thanks for advice
Great news - thanks for letting us know so others can take advantage of your experience.
peter
